09-28-2007, 12:50 AM | #1 |
How do you remove this?
I am looking at the front blinker assemblies on my 68. I want to remove the wiring from the housing so I can get it blasted and painted. How would I remove the wiring?
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
09-28-2007, 12:57 AM | #2 |
Zappaphile!
Re: How do you remove this?
?? which part? Up at the grill, or are you talking about the column?
1969 C20 LWB Camper Special - The Beater.. 1998 Cheyenne V6 - 4/6 Drop - For The Son |
09-28-2007, 01:03 AM | #3 |
Its the blinker assembly that attachs to the grill on a 68.
09-28-2007, 02:47 AM | #4 |
The electrical plug just should just pull apart for the wiring harness. Or are you talking about the bolts that hold the lamps into the grill?
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
09-28-2007, 08:27 AM | #5 |
Active Member
Are you referring to the blinker lights/parking lights?
I think it's the same as my 68 GMC. The rubber connector on the radiator support that's behind the light is a pullout and may be hard to pull it out. |
