09-30-2007, 02:00 PM | #1 |
Whats the correct back seat???
I bought a rear seat for my 71 cst from a guy. He said its stock but there are no arm rests. ive seen a similar truck around town and his back seat has arm rests. It looked much better in his truck. Which one is correct?/or are they both correct????
09-30-2007, 02:08 PM | #2 |
Re: Whats the correct back seat???
They had armrests stock but they may have been removed..
09-30-2007, 02:18 PM | #3 |
Always on the hunt...
The arm rest & support/mounting tube's are attached to the seat with only 3 screws per side and could have been removed from the seat at some point, I have seen it before. It's hard to know/say what you have for sure without any pics of your purchased seat. Does the seat have bent tubular type mounting frames under each fwd corner of the seat? Cb
10-01-2007, 04:05 PM | #4 |
I dont see any mounts.I think the search continues. I guess i need ta find the seat with the arm rests...
10-01-2007, 04:47 PM | #5 |
Mine does not have armrests, as far as I know it's the original seat just recovered...
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks |
10-02-2007, 07:40 AM | #6 |
I've never seen an original without the arm rests. Most likely they are removed. I have the tubes which help brace the seat, but the pads I removed nearly 20 years ago because they were unserviceable at that time. Most likely underneath the seat cover, the holes still exist to mount the tubular supports to which the arm rest pads attach.
10-02-2007, 03:21 PM | #7 |
The LuvShack Garage
I have one done each way, cause I did it (Armrests)
Pic's of brackets and backside / bottom of a rear seat
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
10-02-2007, 04:53 PM | #8 |
Yup, that looks like the bottom of mine...I must be in the "removed by prior owner" club!
