Old 10-02-2007, 09:19 AM   #1
aventur1
aventur1's Avatar
Adjusting Power Steering?
1971....
The power steering seems to easy? Is there a way to adjust? To make it more tighter, theres no slop in turning, the gear box was just rebuilt. Can I adjust it at the gear box? Also am putting a smaller steering wheel on.
aventur1 is offline   Reply With Quote
Old 10-02-2007, 09:31 AM   #2
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Re: Adjusting Power Steering?
Not to my knowledge. There is a valve in the box that controls that, may take it back to your rebuilder. Could just take the belt off the power steering pump, that will toughen things up.LOL
sneakysnake is offline   Reply With Quote
Old 10-02-2007, 10:10 AM   #3
ERASER5
ERASER5's Avatar
Add a steering shock to your drag link just like the 4X4 guys do. That will stiffen thing up a bit as well as absorb some of the road bumps.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 10-02-2007, 10:15 AM   #4
66skylarkpost
66skylarkpost's Avatar
theres a valve in the back of the pump, its the large fitting , where you attach the pressure line . unscrew it and try a few valves from smaller cars ( as in a camaro or chevelle or nova )it may slow it down .
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car
66skylarkpost is offline   Reply With Quote
Old 10-02-2007, 11:38 AM   #5
aventur1
aventur1's Avatar
Thanks for some replys!!!
Removing the belt is a good one, LOL
Old 10-02-2007, 11:45 AM   #6
66skylarkpost
i'd just add that smaller wheel and see how you like it . if you ever put wider tires on the front ,it may be just fine .
Old 10-02-2007, 12:34 PM   #7
aventur1
aventur1's Avatar
Smaller steering wheel, I did think that that would help. Here's the steering wheel I'll put on, just don't know about the horn button? It was not the the wheel.
