10-03-2007, 02:37 PM | #1 |
Between Trucks...
Windshield wipers...
What are some steps for trouble shooting windshield wipers?
Beat it to fit, Paint it to match... |
10-03-2007, 02:56 PM | #2 |
Re: Windshield wipers...
well the first step would be to identify what they are doing or aren't doing thats causing concern
10-03-2007, 02:59 PM | #3 |
Between Trucks...
They don't work at all, and the fuse is good...
Beat it to fit, Paint it to match... Last edited by Sinister; 10-03-2007 at 03:01 PM. |
10-03-2007, 03:06 PM | #4 |
first i'd see if there is 12v at the switch with the ign switch in the on position// then id see if theres 12v coming out of the switch when its turned on
10-03-2007, 03:15 PM | #5 |
Between Trucks...
Thanks, I'll give that a shot. If I have voltage at the switch and coming out of the switch, then the motor is bad?
10-03-2007, 03:52 PM | #6 |
that would be right if you have a good ground at the motor
10-03-2007, 04:53 PM | #7 |
More Cowbell....
There is ZERO power coming out of the factory wiper switch. The power is from the fuse panel to the motor (yellow wire).
The switch offers ground only. Ground the center (Dk Blue) wire for wash. Ground the black wire for high speed. Ground both outer wires (Lt Blue & Black) at the same time for low speed
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket Last edited by Putter; 10-03-2007 at 04:54 PM. |
10-03-2007, 05:16 PM | #8 | |
Between Trucks...
