Old 10-03-2007, 05:37 PM   #1
blazntn
Small 5 on the front
Ok guys I am going to be running the C4 rearend. I am wanting to run the 5x4.75 bolt pattern on the front as well. However, I already have drop spindles and disc that are six lugs. Is the a rotor that fits on the hub that is a 5 lug pattern. I guess I will redrill the the bolt pattern. Are there any other options, besides outragous custom jobs.
www.gaugemagazine.com
blazntn is offline   Reply With Quote
Old 10-03-2007, 05:54 PM   #2
SCOTI
SCOTI's Avatar
Re: Small 5 on the front
Just get stock 5x5 pattern rotors from any parts house & have them re-drilled to the 5x4.75 car pattern. This is how my 74 is done.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-03-2007, 09:31 PM   #3
babyblueoval
babyblueoval's Avatar
Brad,
You know what the best option is.................
DROPMEMBER C4
Jim
'71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E
'57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works
'87 BMW 325i - daily driver
babyblueoval is offline   Reply With Quote
Old 10-03-2007, 09:40 PM   #4
babyblueoval
Actually, I'm having the same problem in the rear.
I'm running the C4 front and want the rear to match, but I have a 5x5 rear so I'm probably just gonna drill the hubs for the smaller pattern. I've already got the wheels so I'm gonna have to do something.
I'm hoping jkaylor is gonna come thru with his kit before I have to have one and I'll go that way.
Jim
Jim
Old 10-04-2007, 11:21 AM   #5
blazntn
so will a what year disc do I need to use. since my truck didnt come with disc?
Old 10-04-2007, 07:53 PM   #6
abadsvt
abadsvt's Avatar
I believe 71 was the first year for disc brakes. What i did for mine was ordered a new set of rotors from CPP (I think it was them) then took them down to a local maching shop and had them redrill them. When they redrill them there is some pieces of metal that have to be lathed down so they have room to redrill them. It has been so long since i have had mine done. I do remember it being a little expensive though. I would have to dig up my reciepts to find the exact price. On the other hand you get what you pay for most of the time. Good luck
Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 10-05-2007, 11:56 AM   #7
Scott68-93-97
Scott68-93-97's Avatar
kore3 has c5 conversion kits check that out, Ive also heard of people running an s10 spindle because there 5x4 3/4 check into that. Just take a unibit to the hole until it fits the ball joint.
1968 Short Fleet 350/700r4
http://67-72chevytrucks.com/vboard/s...d.php?t=249435
1997 Bagged XtdCab Vortec350/4L60e
http://67-72chevytrucks.com/vboard/s...44#post2286144
1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver"
1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap
Scott68-93-97 is offline   Reply With Quote
Old 10-05-2007, 08:57 PM   #8
Robznob11
Robznob11's Avatar
well i dont remember if the 6 lug spindle is smaller than the 5 lug but i do know this the g 10 vans had 5 on 4 3/4 pattern i went to the parts house and compared them to the 72 5 on5 and they are smaller and have smaller bearings. i just wonder if some one makes g 10 drop spindles that would bolt in to are arms with the smaller rotors and pattern. as far as the rear some one else asked about i just called moser ordered replacement axles and had them drilled for the smaller pattern there don't forget to have them turn down the center to fit the car drums on though. you can get the drums at napa dont remember the first 3 # but the important part of the pt# is the last 4#s and they are 1060 they are for late 60s cars with 11x2 drums
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 10-08-2007, 08:41 PM   #9
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
are you freaking serious? Thats the most backwoods excuse for "making something work" I've heard lately. Let's think about this for a second. What does the spindle hold on? oh yeah thats right the FRONT WHEELS. So you're going to take a tapered 1:1 fit, and drill it with a stepped taper, that's probably not the right taper? How much contact will it have with the ball joint then? hardly any! get serious!
Now to answer the original question. Any confident mom &pop machine shop can drill you a bolt pattern in an afternoons work. don't be afraid to get in the phone book if you don't know anybody in the trade.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
