10-03-2002, 12:19 AM | #1 |
In tank fuel pumps and gas fillers questions.
I am planning to put a gas tank from a 87-91 suburban in my pickup. I may also sometime in the future install a TBI or TPI and would like to prepare now when it is easier. If I install the in-tank fuel pump, does it need any computer stuff to run it? I notice on newer vehicles that have FI, the fuel pump will run for a few seconds and then stop when the ignition switch is turned to the on position. Is this few seconds of run time determined by a computer or does the pump build up pressure and then shut itself down when the pressure gets to a certain level?
Also, the point that I am planning to install the fuel filler neck is only about 2-3" above the top of the tank and the fuel filler tube will be about 18" long. Is that enough of a drop to allow efficient fuel filling or will I be at the pump for 20 minutes trying to refill the tank? Thanks in advance for any assistance.
'72 Cheyenne. AC, PS, PB, Rear slider window, tilt. Light yellow (grapefruit yellow according to new sales literature from '72) '56 Chevy short step V-8 (My dad bought it new!!) '70 Olds 442 convertible '70 Olds Rallye 350 |
10-03-2002, 12:58 AM | #2 |
My other Love
Just hook the fuel pump up to a power source only on when the key is on
Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
10-03-2002, 01:00 AM | #3 |
Recovering Truck Driver
I don't know alot about the pumps, but I do know that they require oil pressure to keep running, and a relay runs the pump for a little while before the engine starts, and if it blows an ecm fuse, the pump won't run (I learned this working on my 87 chevy pickup) I don't know anyone who has tried to run these pumps without an ecm, but I would assume there is a way to bypass all the ecm crap and run it off the keyswitch, you may have to hook up more than one hotwire and or ground ( I'd find a good schematic), since the pump is triggered from more than one source.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
10-03-2002, 08:12 AM | #4 |
BE CAREFUL!! In tank fuel pumps are made for electronic fuel injected vehicles. They are in the tank because pumps are more effective pushing fluid then pulling it. Example---some BMW's had two--one in the tank and one midstream.
BUTTTTTTTTTT, before you go and attempt to install a tank with an in-tank fuel pump, (If you are running a carb) got to make sure it is a low pressure (carb) fuel pump as a fuel injection pump will overpower your needle and float in any carb!!!! It will NOT work! Carbs require a max of about 6-8lbs of pressure while fuel injection will be 30-60lbs of pressure, Special fuel lines----fuel line connections to handle the pressure, etc. Don't want to see anyone have too hot a truck!! Huck |
10-03-2002, 09:42 AM | #5 |
I guess I should have given a little more detail on my plans. I am planning to run the larger lines that would be required to supply a FI setup. I figure that since I already have to run lines to the new tank position, I just as well use the larger lines now. If I do the TPI or TBI conversion, I would then aleady have the lines there. I had also planned to install a fuel pressure regulator and set it to 5-6 Lbs. I am presently running a Edelbrock 1406 carb. I liked the idea of an intank pump due to less chance of vapor lock, although I can't really say that I've experienced any problems with vapor lock. Again, if I install the pump now, it would be there if I updated to FI.
10-03-2002, 10:08 AM | #6 |
You don't want to run an FI supply system on a carb, even with a regulator. those pumps will fail if you pressure them down. The pump is on a computer relay also. It would be better to wait, get all the parts to do the injection system, then install it all at the same time.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html " TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410 </A> |
10-03-2002, 10:31 AM | #7 |
Ok, I guess I've been talked out of using the in tank FI unit. Should I run an electric pump that would be mounted near the tank or just use the stock mechanical one that I am presently using?
Thanks to all who have responded so far.
10-03-2002, 11:54 PM | #8 |
its all about the +6 inches
Myself, I'd run the mechanical one. The'll last forever, the electric ones won't.
10-04-2002, 12:08 AM | #9 |
Used to have a truck
Ive run an in tank FI pump before with a carburetor. Primary fuel presssure was 32 lbs . I had a 2 stage system with a 3 port Barry Grant regulator just before the carb and a 2 port holley regulator just before the nitrous solenoid and a return line to send all the unused gas back to the tank. Actual pressure at the carb and at the nitrous solenoid was 6 lbs. I ran that setup for two years and never had a problem with it. All the lines were 3/8" steel with braided steel hoses.
No truck :-( |
