10-05-2007, 02:31 PM | #1 |
USMC
14bolt free floater and D60??? or not? I dontknow how to tell
Thse are the only pics I have. Can any one ID these from the pics I have? These are under a 1970? blazer.
I can only tell by scraping the junk off and looking for the 60 or 44 on the front. Also is there a way to tell a FF 14bolt by looking at it? thanks
Semper Fi |
10-05-2007, 02:36 PM | #2 |
I do everything twice, so what
Location: To the Right. One may go as far to say WAY to the Right
Re: 14bolt free floater and D60??? or not? I dontknow how to tell
60 only got 3 u-bolts, only one on the pasanger side and a plate. corp 14 ff, the axle is held in with 8 bolts at the hub.
10-05-2007, 03:19 PM | #3 |
FF is on the rear there is a hub type asembly sticking out and is not just flat. It will look like the front axle with the stub sticking out.
10-05-2007, 03:23 PM | #4 |
USMC
awesome Thanks for the fast replies. Looks like that front is a D44 having 2 Ubolts The rear is a FF I have a pic of the outside.
Not the diamond in the rough I was hoping for.
Semper Fi |
10-05-2007, 04:59 PM | #5 |
The rear axle in the pic is a 14 bolt F.F. The semi floaters have 14 bolts holding the cover on but the diff. cover is shaped different.
10-05-2007, 05:34 PM | #6 |
check my knowledge, the ff is 10.5" and std is 9.5"? reason for the cover differance?
10-05-2007, 06:12 PM | #7 | |
The rear axle in the picture above is definitely a 10 1/2" full floater. The front looks like a 44 to me, but you can't really tell from those pictures.
Tim |
10-07-2007, 12:26 PM | #8 | |
10-07-2007, 02:45 PM | #9 | |
As far as the skinny tubes, my Dodge Dana 60 has pretty skinny tubes. 3-1/8" IIRC. But, that is definitely a 44...you can see the castle nut on the pass. side knuckle.
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
10-08-2007, 12:29 AM | #10 |
OK,OK,Ok. I know the the 44, 60 and corp 14 ff are different. Look at the 1st post, I know this. 60's have 3 U-bolts, 44's have 4 & corp 14 ff axles mount at the hubs.
What I was wondering is, is the corp 14 bolt NON ff a 9.5" ring gear? And if so, is that why the housing is differnet? |
10-05-2007, 09:28 PM | #11 |
44 front and 14ff rear. Gaurantee it....
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
10-05-2007, 09:41 PM | #12 |
River life......
X2, no kingpins, skinny tubes.
10-05-2007, 10:41 PM | #13 |
10-08-2007, 03:11 PM | #14 |
No problem I wouldnt run a 14blt sf if unless it was so I could use the 6 lug one.
Earl 68 2500 4x4 GMC Burb |
10-08-2007, 03:30 PM | #15 |
Yea, all i'v ever run are FF. I was trying to keep my brain updated. We twist off to many axles to run anything else. A long magnet in a PVC tube is way easier to fix a broken axle at the track than cover disassembley.
10-08-2007, 03:33 PM | #16 |
Has any one compared the new GM axles to the 14bff I was told the axles in the new trucks were way bigger Im sure more expensive if you break an axle but you may not break them as often.
10-08-2007, 03:34 PM | #17 | |
They're putting a 11.5" 14B front into the Dodge Cummins and D-max's. 12.5" 14B rear!!! They're HUGE! Last edited by FormerMember; 10-08-2007 at 03:35 PM. |
10-08-2007, 03:55 PM | #18 |
I picked up two GM 2.5 ton steer axles three weeks ago. Now I'm in the market for a Rockwell 106 w/ 6.20's in it. Now, these are HUGE
10-08-2007, 03:46 PM | #19 |
They look huge the axle in my d-max is massave compaired to the 14blt but you never know what your going to find in side. I would like to see a side by side compairison of the ring gear and the axle shafts.
Earl 68 2500 4x4 GMC Burb Last edited by earl87gta; 10-08-2007 at 03:47 PM. |
10-08-2007, 03:51 PM | #20 | |
Check on Pirate4x4.com |
10-08-2007, 03:55 PM | #21 |
If there price would come down we would probably see more of them in use but the savlage yards around here are still selling them for almost 2k thats more then I want to spend on an axle.
10-08-2007, 09:23 PM | #22 |
USMC
The duramax is has IFS so does it really matter as much? I haven't owned a 1ton chev with IFS but i have owned 1/2tons that were really bad about wearing out and breaking steering parts. Much more than any solid axle truck I have run.
Does the ring gear really matter that much if its not the weak link? The CV joints and half shafts would go before the ring and pinion wouldn't it?
Semper Fi |
10-08-2007, 09:24 PM | #23 | |
Dodge uses a 14B in the front of theirs... |
10-08-2007, 09:54 PM | #24 |
USMC
DOH
I knew that all along ......... UMM just checking if you knew.. LOL(J/k)
Semper Fi Last edited by DURRTY; 10-08-2007 at 09:54 PM. |
10-09-2007, 01:04 AM | #25 |
the new dodge front is a good axle you can pick one up for around 600 but after you pay 2k for the lock out hub convertion for it you would be better off to get a built d60.
Earl 68 2500 4x4 GMC Burb Last edited by earl87gta; 10-09-2007 at 01:04 AM. |
