350 sb
the number one lifter is lose an it sound like it missing but all new plug an wires had cam work done an no speed like before what should i change all the liter are get new head the head are iron head
Wishin' I had more money!
Re: 350 sb
Ummm...
![]() ![]() Your lifter is loose? Or your rocker is loose? Why can't you tighten it up? Really confused on this one... |
Re: 350 sb
my rocker are loose an can not tighen them no more will that make it loose compresson
Re: 350 sb
if i get the head redone will i needs to do the cam to
#5 | ||
Garage Queen Material
Re: 350 sb
I corrected all of your vocabulary. Maybe now you might get an answer to your question since it took me 10 minutes to figure out wtf you were trying to say. |
Re: 350 sb
![]() Thanks for interpreting that ocbaud. First question I have is are the rocker studs press-in or screw in? It sounds like they are press-in and they have worked their way out. Yes, that will make the engine lose compression. I do not think it is possible to fix this without removing the heads and having a machine shop tap them for screw in studs. I have heard of 'pinning' press in studs, but they would need to be set at uniform heights first, then the boss is drilled thru the stud and a roll pin inserted - not easy to do with the head on the engine intalled in the truck. Next question is what are the specs for the cam you have installed? Is it hydraulic or solid, roller or flat tappet? Third, what is the seated pressure, installed height, and coil bind specs for the valve springs? Fourth, what is the rocker arm ratio? Fifth, what length pusrods do you have? Did you check the valve geometry to make sure they are the correct length for your engine? And have you made sure none of them are bent?
- Greg Last edited by 454HO; 10-06-2007 at 11:35 AM. |
Re: 350 sb
the rocker are screw in the push rod i does knew if they are bent i got the from out of my state an did not know what all he did with the engine he use th race with it
#8 | |
Re: 350 sb
#9 | |
Chevys Kick A$$
Re: 350 sb
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
![]() Last edited by Hoods69BadBowTie; 10-06-2007 at 05:50 PM. |
Re: 350 sb
I would consider the fact that your cam may be going flat. If you pull the valve cover off and have someone turn the motor over, you should be able to see if that pushrod moves up and down as much as the others. Jeff
