10-06-2007, 02:16 PM | #1 |
Freeeeee Mason...
Odd Headlight Problem
About 6 months ago I converted my headlights to the H4 sealed versions and a high output 240 amp alternator. I highly doubt this has anything to do with my problem, but I'll throw it out there anyway. I was driving into Taco Bell last night, parked the girl out front where I could see it, and switched off my headlights. I go to get out of the truck and see bright lights in the window of the Taco Bell... WDF? Those are MY headlights. I check the switch, and its off... Are they really mine? I go around to the front and sure enough, my low beams are on. I messed with the switch a little, thinking maybe it just didn't get into the off position correctly, but this didn't fix the problem. The night had just started so I just left em on, got my food, and left. I stayed the night at my girlfriends and to keep them from draining the batter, I pulled my + cable. Woke up this morning, hoping it was a dream (because lately it seems that every other week something is going wrong), but was disappointed when I hooked the battery up. I replaced the headlight switch this morning, to no avail. The only thing I can think of is a direct short or bad relays... Any other things I should check for? I'll probably go through all the wiring today.
10-06-2007, 02:38 PM | #2 |
Overdrive club
Re: Odd Headlight Problem
Check the dimmer switch!!!!!!!!!
1971 c-10 1951 3100 chevy 1970 chevy c-30 Sold! |
10-06-2007, 02:40 PM | #3 |
its all about the +6 inches
start with the relays. I'd just swap the relays and see if the highbeams come on/stay on. Then you can simply leave the highbeam one unplugged and take the bad unit into the parts store with you.
May as well get both. I've seen a lot of real cheap junk relays come in kits, and if one went this soon, it's safe to assume the other may be going shortly too. |
10-06-2007, 03:01 PM | #4 |
to try the relay give it a wack wth the handle of a screwdriver if lights go out replace relays
10-06-2007, 07:21 PM | #5 |
I forgot all about that trick!
