10-06-2007, 08:34 PM | #1 |
pkbinplano
It's all on and I'll never do it again
Don't want to, don't have to and you can't make me. Total front end rebuild. Upper/lower control arm bushings, upper/lower ball joints, inner/outer tie rods, idler arm, pitman arm, shocks, brakes, brake lines, bearings and seals, all thats left tomorrow is put rotors and brake shoes on, flush and bleed system and get it alligned. Total cost minus allingnment $780 . NTB wanted $1400 just for upper/lower control arm bushings.
http://www.picturetrail.com/gallery/...7496&members=1 84 chevy silverado aka The Bananna Boat |
10-06-2007, 09:00 PM | #2 |
Re: It's all on and I'll never do it again
Thats a lot of work. Did it earlier this year. Congratulations.
10-06-2007, 09:24 PM | #3 |
Way to go man ... should be good for another 30 years!
10-06-2007, 09:28 PM | #4 |
Spear and magic helmet!
Never, huh? 30 years from now they're gonna want even more than $1400, you know...
-- Will |
10-06-2007, 09:45 PM | #5 |
pkbinplano
77 step, what color is your ride ? I'll keep an eye out for you
10-07-2007, 03:42 AM | #6 |
I feel your pain. I've done the 4wd version (tie rods, drag link, U/L Ball joints, Axle U- Joints, leaf spring bushings) twice. Once on one of my current trucks and the second on a previous truck that I owned. It was tedious work but it saved me a lot of $$.
10-07-2007, 04:18 AM | #7 |
Dark Heart Motorsports
yeesh...Im gonna have to talk to the wifey if I wanna do anthing like that...gotta have approval ya know? lol
How Deep Can YOU Bleed..? 1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter 2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD! |
10-07-2007, 09:06 AM | #8 |
That truck is gonna ride better than when it was new!
Eventually I'm gonna have to do my front end too. I'm sure the results are well worth the work.
79 Jimmy slammed AKA James Down |
10-07-2007, 09:35 AM | #9 |
83C10SWB
just curious, did you have to do anything with the steering box itself?? Mine has started leaking ps fluid and the steering is not tight like it used to be, alot more play in the steering that i like.
Koreric75 2003 Suburban Z-71 4x4 5.3L 83 C10 SWB FOR SALE 350ci/700Raptor Jr Picture&Progress Page |
10-07-2007, 10:02 AM | #10 |
Truck and auto performance nut
there's usually an adjustment on top with a lock nut, that you can take some of the slop out. release the locknut and turn the center post slightly to tighten.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
10-07-2007, 11:36 AM | #11 | |
The One And Only !!!
So, Keep your hands off/away from the steering wheel to prevent broken fingers for the first fire-up after adjustment.
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
10-07-2007, 11:52 AM | #12 |
83C10SWB
Thanks for the warning, will try to take some of the slop out, my haynes manual got wet after the heater core leak so i need to get a new one to help on stuff like this...lol.
10-07-2007, 12:06 PM | #13 | |
Robert Current: 1986 SWB Silverado 4.3 / TH400 Past: 1985 SWB Silverado 305 / TH350 - sold 1995 1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007 Last edited by C&C Chevy; 10-07-2007 at 12:06 PM. |
10-07-2007, 01:07 PM | #14 |
pkbinplano
just took it for a drive. Rides like a Caddy again. Kicker is the wheel is straight, and it doesn't pull to one side. Guess I did my measurements correct. Just dropped it off for allignment.
10-07-2007, 07:15 PM | #15 |
BAD BOW-Silverado XST
10-07-2007, 07:49 PM | #16 |
pkbinplano
what special tools did you use that would make things easier ? Maybe a pneumatic chisler
10-07-2007, 09:53 PM | #17 | |
I rebuilt my whole front end also before I decided to go ahead with the body-off. My special tools were a 6" bench vice, 3/4" drive socket set and a BFH. But being in the repair biz I knew how/what needed to be done.
10-08-2007, 07:49 PM | #18 | |
I'm definitely not a pro though -- even with the power tools - the job sucked |
10-08-2007, 09:06 PM | #19 |
pkbinplano
yup. The ball joint press I rented helped alot, along with a electric impact I bought awhile back. Best investment ever.
10-08-2007, 11:45 PM | #20 |
I am getting ready to do all the same thing, but with some aftermarket lower a-arms and spindles. Let us know how the truck feels compared to how it was
1981 Custom Deeluxe SWB 5.3/4L60e 3.73 and Auburn. Mustang Dyno 265hp/258tq |
10-09-2007, 06:51 AM | #21 |
pkbinplano
drives like a Caddy again. Ultra quiet over RR tracks.
10-09-2007, 10:17 AM | #22 |
glamoros piece o' lowlife
I rebuilt the front end of my Lincoln last summer, using all ultra-heavy-duty DANA parts from NAPA - ran me a bit under $500, but I had a serious discount at the local store. Now I wanna rebuild the truck too, but I got tuition to pay and not enough time to fiddle with rusty hardware and other joys of that sort - I already have all new brakes and hoses and lines tho, so maybe I'll just get a set of control arms off a junker truck or somethnig and rebuild them on my free time and then just swap them in over an evening after work...
The more I drink, the more I drink, the more I drink... diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express |
