Old 10-09-2007, 01:16 PM   #1
70GMCer
70GMCer's Avatar
Carb Return spring kit info needed
Has anyone used this setup? If so, do you have a picture or better yet, instructions on how to install?
http://cgi.ebay.com/ebaymotors/ws/eB...MEWA:IT&ih=013
thanks......
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 10-09-2007, 01:44 PM   #2
BHRS
BHRS's Avatar
Re: Carb Return spring kit info needed
I bought mine from Summit Racing and it came with instructions. Basically the bracket bolts to the carb base and faces forward. The bushings go in the large hole on the throttle arm with a bolt and another bracket. The springs attach to the bracket that bolts to the base and smaller bracket on the arm.
I don't have pictures with me, but I can take a few this evening and post them...
It works "OK"-the biggest pain in the rear was getting the springs installed.
Brian
1972 Cheyenne C10
Unrestored Original-3 Owner-RUST FREE Texas Truck
Big Block-TH400-PS-PB-AC-AM/FM Radio
BHRS is offline   Reply With Quote
Old 10-09-2007, 01:51 PM   #3
70GMCer
70GMCer's Avatar
Yes, if you could post pics, that would be great.......
1997 GMC Sierra Ext
1965 Mustang
Old 10-09-2007, 01:56 PM   #4
BHRS
BHRS's Avatar
I will get some on tonight...
Brian
1972 Cheyenne C10
Old 10-09-2007, 09:19 PM   #5
BHRS
BHRS's Avatar
Here are some pictures of mine. The carb is a Holley 1850-3 and the manifold is an Edelbrock Performer 2-0.
Brian
1972 Cheyenne C10
Old 10-09-2007, 10:08 PM   #6
68C15
blood type; Retumbo
68C15's Avatar
IMHO those are the best design for return springs ever. they dont wear out the shaft and are accurate. except I would mount the throttle cable to the large hole for a less touchy pedal. i had the same setup on my 80K20 with a highly modified 4776. it worked flawlessly.
68C15 is offline   Reply With Quote
Old 10-10-2007, 04:34 PM   #7
70GMCer
70GMCer's Avatar
Thanks Brian.....that really helps......
1997 GMC Sierra Ext
1965 Mustang
Old 10-10-2007, 04:46 PM   #8
BHRS
BHRS's Avatar
If you buy it and still need the instructions, I can fax them to you.
Brian
1972 Cheyenne C10
Old 10-10-2007, 04:53 PM   #9
70GMCer
70GMCer's Avatar
I already had bought it. I'll go by the pictures. If I need the instructions, I'll let you know.
thanks again......
1997 GMC Sierra Ext
1965 Mustang
Old 10-10-2007, 05:45 PM   #10
70GMCer
70GMCer's Avatar
Got it installed just now......Works great. Only hard part, was putting on the springs. They were a bear!!
1997 GMC Sierra Ext
1965 Mustang
Old 10-10-2007, 05:51 PM   #11
BHRS
BHRS's Avatar
Looks good. See...I told you they were a pain in the rear...LOL
1972 Cheyenne C10
Old 10-10-2007, 09:44 PM   #12
corn
Do you happen to have a pic of the whole engine?
corn is offline   Reply With Quote
Old 10-11-2007, 01:41 PM   #13
70GMCer
70GMCer's Avatar
Forth coming. I haven't finished getting all the parts on yet. I have completely changed the look of this engine. "70c10 " will not let me live it down either.
1997 GMC Sierra Ext
1965 Mustang
Old 10-10-2007, 05:58 PM   #14
TonyJohnson
TonyJohnson's Avatar
My return spring broke this morning on the way to work and the revs shot up to 4K... I could tap it back, so I limped to Walmart (the only place I could find at 7:30...) and bought a small bungie cord and some duct tape. It was a quick fix, and worked great, but the dual spring setup has real appeal for me after the sound of my engine screaming.
Tony Johnson
-- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer --
TonyJohnson is offline   Reply With Quote
Old 10-10-2007, 06:24 PM   #15
70GMCer
70GMCer's Avatar
But, as they say.....If you can't fix it....duck it......
1997 GMC Sierra Ext
1965 Mustang
Old 10-10-2007, 07:21 PM   #16
jaros44sr
jaros44sr's Avatar
Man, that set up came out sweet, I have Lokar cables on mine, but I like the idea of my springs not wearing out my shaft, I'll have to put it on the todo list. Thanks for the idea
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 10-10-2007, 08:44 PM   #17
70c10
67-72 Addict!
70c10's Avatar
Looks good Steve!. Where did you get it?
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 10-10-2007, 09:16 PM   #18
red69ss
Burnouts are therapeutic
red69ss's Avatar
I have the same setup bought it from summit I love it
1969 CHEVELLE SS
1972 C10 ALMOST DAILY DRIVER
1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE)
1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR)
"My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield
"The difference between genius and stupidity is that genius has its limits." - Einstein
red69ss is offline   Reply With Quote
Old 10-11-2007, 01:43 PM   #19
70GMCer
70GMCer's Avatar
This is where I got mine. Fast shipping also.....
http://cgi.ebay.com/ebaymotors/CARB-...QQcmdZViewItem
1997 GMC Sierra Ext
1965 Mustang
