Old 10-09-2007, 04:07 PM   #1
joehalford01
joehalford01's Avatar
fabricating tube a-arms
I've been doing some research on bagging my 63 and I was looking at the tubular upper a-arms as part of it. I'm curious, has anyone here fabricated their own? Is there any reason why you couldn't make a set with some steel tubing, metal plate, a chop saw, and a mig welder? Don't get me wrong, it would obviously have to be built strong to withstand all the stress but aside from that is there anything else? I would basically take the stock upper off and use it's shape as a template to get my angles correct as far as that goes too.
joehalford01 is offline   Reply With Quote
Old 10-09-2007, 04:52 PM   #2
raggedjim
raggedjim's Avatar
Re: fabricating tube a-arms
This guy has done it, the pics disappeared but I had saved a couple of them to my flash drive.
http://67-72chevytrucks.com/vboard/s...d.php?t=192228
I've also thought of ordering some from a racing supply place and changing out the cross shaft... but I've never done it. The prices on the arms from these places are great...
http://www.joesracing.com/catalog/20...ng_Catalog.pdf
Good luck, Rg
raggedjim is offline   Reply With Quote
Old 10-10-2007, 01:55 PM   #3
joehalford01
thanks for the pic dude, this is something i'll have to think about.
Old 10-10-2007, 03:45 PM   #4
blazntn
what do you do about the lower cross shaft? I am running the Dropmember and I am thinking about getting a set made.
blazntn is offline   Reply With Quote
Old 10-12-2007, 11:17 AM   #5
impala_631
:( BYEBYE :(
impala_631's Avatar
if you made once set i would make a jig so that you can make them quick and sell en
impala_631 is offline   Reply With Quote
Old 10-13-2007, 01:20 AM   #6
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
IvelDesigns is offline   Reply With Quote
Old 10-13-2007, 02:20 AM   #7
joehalford01
well i'm ways off from this at this point, just figuring out options right now. I still need to finish diassembling the truck so i can start some of my frame work
Old 10-17-2007, 09:41 AM   #8
azfab
azfab's Avatar
nice work man!
azfab is offline   Reply With Quote
Old 10-17-2007, 12:11 PM   #9
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
I have some tube lowers for $150 you just need to make your own crosshafts and get bushings. Used them on the new arms we built. PM ME
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
