Old 10-10-2007, 02:21 PM   #1
ChevyDude
Torque Specs, Front crossmember???
Does anyone have the torque specs for the lower 6 bolts (3 a side) that connect the front crossmember to the frame. Also need the torque specs for the 8 bolts (4 a side) that connect the front crossmember on the side of the frame.
Thanks in advance!!!
Alex
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 10-10-2007, 02:55 PM   #2
SactoJim
SactoJim's Avatar
Re: Torque Specs, Front crossmember???
I just made mine really really tight!!!
BTW.....frame looks very nice.....is that for your new project or is that a pic from the Red truck?
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 10-10-2007, 03:38 PM   #3
ChevyDude
Thanks Jim. This is the frame from my 68'...Project OverKill.
Alex
Old 10-10-2007, 04:24 PM   #4
70GMCer
70GMCer's Avatar
Don't know....you should have put in an extra "really" on the tighting.....
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 10-10-2007, 06:31 PM   #5
WorkinLonghorn
WorkinLonghorn's Avatar
Hope this comes out OK> 65 for C-10 and 100 for C-20/30
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 10-10-2007, 09:28 PM   #6
Pitts1e
Pitts1e's Avatar
One grunt...not two. I used the same chart as above and it tightned down nicely. Make sure you use grade 8's! I was going to use stainless till I started thinking about how it would all go horribly wrong if that fell off whilst driving.
Will this thing ever get done!!
Pitts1e is offline   Reply With Quote
Old 10-10-2007, 10:07 PM   #7
Sequoyah
so easy a caveman can do it...
Sequoyah's Avatar
Alex
...just had to quote you so that pic was in the thread twice! That looks great! I don't want to do that with mine, but I'll probably end up doing it anyway!
Well, it didn't work...oh well
Sequoyah is offline   Reply With Quote
Old 10-11-2007, 12:24 AM   #8
ChevyDude
Thank you WorkinLonghorn.....and here ya go Sequoyah, the project is named OverKill....so not much being over looked. Grade 8 for sure.
Alex
Old 10-11-2007, 12:41 AM   #9
whatnow123
whatnow123's Avatar
I have to agree with the "toss in an extra really" comment, this isn't something where the the torque specs matter however, I know it's probably a long shot on it happening, but looking at the photo of the frame, I'd run the bolts with the nuts on the bottom. If by chance all six nuts loosened up, the bolts would fall right out and there goes the front. If the bolts were reversed, it would be loose but wouldn't come out from under the truck. But, it's probably not something that would ever happen.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners.
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=219094
whatnow123 is offline   Reply With Quote
Old 10-11-2007, 03:05 AM   #10
ChevyDude
Bolts ain't comin' loose once I torque them down, and they came this way from the factory.
And in that case.....maybe I should turn the U bolts over that hold the lower control arm on ...so when the nuts fall off, yeah right....LOL!!!
Alex
