10-12-2007, 01:34 AM | #1 |
Suspension and box....
Ive seen pictures where truck had the leafsprings on the bottom of the axles, and was just wondering; 1. Has anyone here done this? and 2. How many inches of drop is that considered?
Also, will any year(73-87) of shortbox(fleet) fit my 80? Or will I have to look for a specific year? Thanks |
10-12-2007, 02:35 AM | #2 |
Re: Suspension and box....
the amount of drop will be equivalent to the thickness of your leaf pack, and the distance from the very bottom of your axle tube the the flat part of the perch. typically about 5".
any bed will work from 73-87 will work, unless you want to go stepside, at which point, they're the same all the way back into the 50s IIRC. |
10-12-2007, 03:33 AM | #3 |
You need a flipbracket to put the axle on top of the leafspring.It locates the axle in the proper spot and angle! I installed a flip kit from Bell Tech and that wasnīt to complicated.Additional you should extend the shockmounts or get shorter shocks and in most cases the frame is notched to give enough room for the axle to travel without hitting the frame.I didnīt notch the frame on my longbed but the bumpstop is pretty close to the axle.
The last picture is how it looked before! |
10-12-2007, 09:43 AM | #4 |
with a flip kit, how does the pinion any stay where it needs to? is there a new bracket welded to the bottom side of the axle tube
1981 Custom Deeluxe SWB 5.3/4L60e 3.73 and Auburn. Mustang Dyno 265hp/258tq |
10-12-2007, 10:33 AM | #5 |
Happy to be here
The axle saddle that comes with the flip kit acts as a locator. Look at the pic below and you can see how it goes in the bottom of the original spring perch. The bottom has a hole that the pin in the spring pack sits in. This ensures that the axle isn't going anywhere.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 10-12-2007 at 10:34 AM. |
10-12-2007, 10:37 AM | #6 |
Happy to be here
Technically any year will fit. Keep in mind that your 80 fleet bed has a gas filler door. Early beds (73-78?) had an external gas cap. See my 77 Cheyenne as an example below
10-12-2007, 01:37 PM | #7 |
I'm actually converting the box from a stepside. The gas tank is on the passenger side, so I guess Ill have to look for a fleet with the gas door on the right.
And those flip kits look like theyll work perfectly for the drop I wanna achieve. Where did you get yours moneyeater? Thanks everyone Last edited by 1980GMC; 10-12-2007 at 01:39 PM. |
10-13-2007, 02:58 AM | #8 |
My Bell Tech parts came from Speed & Truck World in Ft. Lauderdale, Florida but you can order it from Summit,Jegs or mostly any store that carries suspension parts i think.
There are other brands too like DJM or Western Chassis.Maybe the some other helpfull boardmember can help with finding the best shop to buy the best part because i got mine 10 years ago and friends brought it to me from their vacation in Florida and in that time Bell Tech was the only name i knew! |
10-13-2007, 05:02 AM | #9 |
Wishin' I had more money!
Here's the belltech kit: http://www.streetbeatcustoms.com/bel6850.html
note that the picture shows new leaf springs, which is not what you'll get in the kit. It's wrong. Here's the McGauphy's kit http://www.streetbeatcustoms.com/mcg33156-d1.html |
10-14-2007, 01:55 PM | #10 |
The leafsprings arenīt new i just removed the rust gave them a coat of paint and greased them.I also removed two layers and that brought the rear down a little more.I hope it smoothes out the ride!? |
10-14-2007, 08:56 PM | #11 | |
moneyeater, so the flip kit in your pictures is from belltech? It looks like a nice kit, does anyone have any pictures of the Western Chassis kit?
10-14-2007, 09:14 PM | #12 |
yeller
WC's kit looks identical, only grey. I have their flip kit, very pleased with it.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
10-15-2007, 06:13 PM | #13 | |
On that website it showed a new set of drop leafs with the flip kit, and that's not what you get in a flip kit unless you buy a package deal. |
10-15-2007, 12:06 AM | #14 |
Happy to be here
You can price DJM as well. I don't have pics but I have used their kits and was pleased with the quality. Try www.summitracing.com. It's almost impossible to beat their prices.
