Chevy nut
What am I getting myself into?
I found a 85 Camaro that is totaled. Guy wants 200.00 for it. It has a 5 speed in it. I am thinking about the 5 speed for the 69. Does anyone think this will hold up to my truck??? Or will it fail pulling the weight of the truck?? Anyone done this swap before??
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II "Remember kids there is NO replacement for displacement!" |
Re: What am I getting myself into?
not enough "return" for all the effort it's gonna take to make this work ... just my .02 cents worth.
Does it have a V8? You certainly can part it out and it would not be hard getting your initial investment back and even make some money on top. I give you a $150 for the engine! However, unless your truck is setup for road racing you are not really benefiting from all of this. An automatic will always be faster than a Manual Transmision. You can buy a new TH350 from advance ($350), put a shift kit in ($60) and be done, no worries. $.02
There is no replacement for displacement! |
#4 | |
Chevy nut
I have 350 THM in the garage already with 2800 stall and a shift kit. When it come to trucks...my truck was perfect for me. No options. No power steering, No power brakes, no auto trans, no air. I didnt want anything to rob the motor for power. When I think of a truck....I think of a workhorse. Manual trans is what I have always had in a truck. If I was to change out to a auto I also have two 400 turbos sitting on the floor...one with less than 10,000 miles on it.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II "Remember kids there is NO replacement for displacement!" Last edited by caminokid; 10-14-2007 at 03:45 AM. |
the pickup doesn't weigh a lot more than the camaro C-10s are fairly light for a pickup, I think it should work i don;t know anything about transmissions (correct me if i am wrong someone) but I believe the transmission is a 700R4 in the camaro and lots of guys have used them in c-10s
1967 c-10 longbox project, check it out in projects 1969 c-10 parts pickup, twisted frame Daily driver- 1970 Olds delta 88, 2dr., 455, gotta love the big block |
its all about the +6 inches
the tranny in the camaro is a T-5.
Not rteal strong, and would be mounted at an angle in the truck, which can cause lube issues. try a search, it's covered every few months. |
The trans would run a C/10 around to save on fuel.But,to add bruteness to a truck,you`d be better off with a 700R4 for o/d or just a truck 4spd to keep it simple and strong.
