Old 10-03-2002, 11:43 PM   #1
useRc10
useRc10's Avatar
gas gauge probs
i've tried everything i can think of and i'm about to give up on having a working gas gauge unless someone has another idea...i've put 2 new different sending units ina nd one is known to be good cause ibought it from a board member...i've hooked it to another cluster i have to see if it was the gauge itself...i've run a new wire from the sender to the gauge to see if it was in the wire...i checked the fuse and connections in the fuse box...it still doesnt work...it sits at a little more than 3/4 while it used to sit at about 1/4 of a tank...i have no idea...my next step would be to buy all new (not used parts) but i cant afford that now...thanks for any help...-Nick
-'02 Chevy Avalanche, 5.3L, 4x4... needing a small lift and bigger tires
-'72 Chevy C-10(350, bored 60 over)dual flowmasters, 3 on the tree
-'85 K5 Blazer,305 NO MORE...350 is in,2" lift,33" Mickey Thompson Baja Claw Radials
-dads '70 burb (red, 5-7 drop, 350...)
www.geocities.com/userc10/truckhome.html
AIM: Auntjoedadda
useRc10 is offline   Reply With Quote
Old 10-03-2002, 11:44 PM   #2
Tim Christian
Tim Christian's Avatar
Do you have a good ground going to your dash?
Tim Christian is offline   Reply With Quote
Old 10-03-2002, 11:50 PM   #3
useRc10
useRc10's Avatar
all the other gauges work but i'll check tommorrow
AIM: Auntjoedadda
Old 10-04-2002, 07:36 AM   #4
gmcnorton
gmcnorton's Avatar
GAUGE PROB
I'M SURE TIM IS CORRECT.... PROBALLY A GROUNG WIRE PROBLEM. HAD THE SAME TROUBLE WITH MINE AND IT WAS THE GROUNG WIRE CORRODED INSIDE THE WIRE LOOKED OK BUT WAS BAD INSIDE....
70 GMC SHORT STEP , 71 BLAZER ,72 JIMMY,72 BLAZER, JUST NEED THAT SUBURBAN NOW......WANTING MORE
gmcnorton is offline   Reply With Quote
Old 10-04-2002, 02:23 PM   #5
MStokes
MStokes's Avatar
There are lots of post on this board about fuel gauge problems. I agree with most of the replies that say check your ground first. I messed with my sending unit/wire/gauge for quite awhile before I bit the bullet and ordered a new gauge. It has worked fine since I installed it.
1972 C-10 LWB, 400/350, 2WD
1972 C-20 Custom Camper, 350/350, 4WD (Converted)
MStokes is offline   Reply With Quote
