10-13-2007, 10:16 PM | #1 |
Steering wheel paint?
Anyone paint there steering wheels? If so what paint did you use and how is it holding up. Mine is white but is it peeling pretty bad.
09-12-2012, 08:57 PM | #2 |
Re: Steering wheel paint?
i did mine...i wet sanded it sprayed in with rustolium 2 times coverage.
glosswhite let it dry in the sun 2-3 days before touching it..mine held up 3 years now
Measure with a yard stick Mark with Chalk Cut with a torch Built it yourself, don't count on others to to do it for you or with you. It will never get done |
09-12-2012, 09:22 PM | #3 |
There are a few threads in here about that. one guy used filler to take care of the cracks and even opened them up a bit to give the filler more to grab to.
09-12-2012, 10:11 PM | #4 |
I'll second the rustoleum finish. just be sure to use the rustoleum primer so it's compatible with the finish coat. just be sure to let the undercoat flash off the solvents before recoating
09-13-2012, 08:32 AM | #5 |
Since the thread was started in 2007 he has probably already figured a solution lol. 5 year response time
I am glad however I ran into this as I asked this same question a while ago and did not get a response. |
09-13-2012, 06:19 PM | #6 |
UCA63
LOL ....good eye Bill
member#7816 "63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt '61 GMC in progress '63 GMC to use for parts '90 Chevy Ext cab sbfs 5.7l (current d d) |
