![]() Join Date: May 2004
Remote Starter Solonoid, someone check my homework please.
I'm wiring up a remote starter solonoid using a firewall mounted unit from an '87 Crown Vic.
Have I got this right? See below
Also, does it matter which battery post on the fire wall mounted solonid I use for which battery cable? Will mounting the solonoid to the firewall be sufficinet to ground it?
![]() ![]() Last edited by Zonaman; 10-14-2007 at 11:22 PM. |
Re: Remote Starter Solonoid, someone check my homework please.
I think you need to jumper the S term. to Batt. on the starter also.
How's the weather in Phoenix? I know..beautiful! Lived out there twice. But always end up back in Topeka. Oh well third times a charm. Last edited by airdale94; 10-14-2007 at 11:50 PM. Reason: add |
I did this on both my 67 and the 48. It makes no dif which bat cable you put which terminal. There should be no additional grounging required. And don't forget the jumper from the "s" terminal on the starter to the bat terminal on the started. Good thinking, this works great, no more having to pop the hood and jump the thing to get it started.......
hooberjon@yahoo.com "Life's Been Good To Me So Far" 1941 Chevy PU (new project, right out of the field) 1948 P/U: 350/700r4, Nova Clip,Chevelle rear, air ride suspension, custom door handles, custom firewall, custom dash, buckets and console, visor 1967 C20: 427 Tall Deck, Turbo 400 with Gear Vendors aux tranny, 5th wheel, 3500 bucket seats and console. 1996 Geo Tracker 2x4 1996 Geo Tracker 4x4 |
Between Trucks...
Beat it to fit, Paint it to match... ![]() |
#5 | |
Thanks again.
![]() ![]() Last edited by Zonaman; 10-15-2007 at 12:38 AM. |
Designated A-hole!
Here's how I would do it if it were me.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
Between Trucks...
Come to think of it that is how I did mine on my old '72. I jumpered the s and battery terminal on the starter with a flat piece of steel with a couple of holes drilled in it...
Beat it to fit, Paint it to match... ![]() Last edited by Sinister; 10-15-2007 at 01:42 PM. |
Designated A-hole!
Less wiring (lower cost and less to get against a manifold and melt, etc).
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Here's another version of Krue's. It allows connections to the positive side of the battery at the solenoid without crowding the battery terminal. The thing to remember is the whole purpose of the remote solenoid is to provide a full 12 volts to the starter solenoid by eliminating the voltage drop on the purple wire hooked to "S". The shorter this wire is the lower the voltage drop.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
12 guage ok for the short jumper from S to Bat.?
Old member
This shows the battery hot all the way to the starter all the time. I don't think this is the right way to do it. A solenoid is only a electric device to turn on /off another device that draws lot's of juice.
The red wire from battery should run between both of the bigger terminals and the activating circuit should run between the two smaller terminals of the solenoid. These are two seperate circuits. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
That's right, it's Copper!!
Sinister is RIGHT, the Ford solenid is being used as a type of relay just to get 12V to the "S" terminal. The Ford solenid is not being used as the starter solenoid.
#13 | |
Used Register
The Ford unit IS the new solenoid and you BYPASS the original solenoid function at the starter with the shorting bar. That is how this corrects a hot start problem. The hot start issue prevents the S terminal at the factory solenoid from properly functioning due to an increase in resistance in the windings as a result in an increase in ambient temperature. This would still be a problem if the S terminal was stilled used at the stock solenoid location. Herb |
#14 | |
![]() Let me guess why people would use the solonoid: Easier to start with a screw driver & easier to get a remote start switch on it.
#15 |
When you buy a "Hot Start" kit, from like Summit. What you get is the remote (Ford) solenoid, a small flat piece of steel to jumper the "S" and Batt. term on your starter's solenoid, and instructions that say to run your purple wire to the remote solenoid.
As for grounding of the remote solenoid, just make sure you scrape the paint off around the screw holes and you should be fine. That's what it says to do in the instructions if you buy a kit. Last edited by airdale94; 10-15-2007 at 07:15 PM. Reason: add |
#16 |
Old member
The reason for a solenoid to be used in a electric system is for amp draw on high voltage circuits. The two bigger studs on the Ford solenoid are for the high amp load. The two smaller terminals are for the actavation circuit. Which is usally lower amp's.
I have wired plenty of solenoids on golfcarts ranging in the 36,48,72 to 120 volt range with 450, 500 amp's. The solenoid is just a on/off switch that uses a small amount of voltage like 12 volts low amps to activate it. This is a solenoid rated for 90 volts top's, I have 72 volts running through it. It's activated by 48 volts the sonenoid see's 450 amps when I stomp on it at take off. It's $90.00 and rebuildable also it will handle about anything you throw at it. It's rated at 600amp's If you have it wired like the drawing I copied in my first post the high amp load is running through the small wire going to the starter's "S" terminal. This will burn it up sooner I would think from the high amp load. The A and B terminals should be isolated from the frame ground by design. The battery wire should run to the A post of ford solenoid then from the B post to the starter. The NSS should run to the S terminal of the ford solenoid then back to the negative of Battery out of the I of the ford solenoid or to frame to complete the circuit. Then put the jumper between the starter studs as before. ![]() Now is everybody confused!!! ![]() ![]() ![]() ![]()
#17 |
laying low
![]() Join Date: Mar 2001
Fellas those are some nice drawings you've shown of the remote starter relay kit for the hard start problem some vehicles experience. Now I'm no electrician and don't know anything about high amp and low amp draw and all but I've always owned GM vehicles and I've not found it necessary to mod the factory wiring on any of them to get them to start when hot. It is my understanding the problem is heat sink at the starter. I am familiar with the no start condition when hot with small and big block engines. Often this would start to occur in less than 2 years on GM cars of the 60s and 70s.
A local German starter/ alternator repairman had the cure. The factory starters were too weak to overcome the heat sink hot start problem so he beefed them up almost doubling their power. He explained to me the stock starter came with 2 fields and 2 shunts. He replaced the 2 shunts with 2 more fields making it 4 fields. Of all the starters he built for us and I'm talking about dozens never once did one fail to startup at first try and lasted for years and years and was easier on the battery too. He was aware of the "kit" GM and some parts stores were selling as the fix and scoffed at it. " it's a patch and a gimmick to sell parts that weren't necessary he said. Wiring this kit into the vehicle just added more electrical connections and switch to give a problem later on." He usually charged us about $30 to beef one up back then. I suggest instead of going to "the zone" or advance or bumper for your next starter make a stop at your local starter rebuild shop and see if they can build a stout one for you or buy one of the high torque minis instead of using one of these kits. It will be easier on the cables and battery and alternator.
#18 |
Half a bubble off!
Kit with complete diagram: http://www.madelectrical.com/catalog/st-1.shtml
This guy writes for automotive magazines, came up with this kit several years ago. If you don't know exactly what you are doing, I highly recommend going this route and saving yourself some trouble. His diagrams are correct and easy to follow and understand, and everything you need is in the kit. I talked to him on the phone once, sharp guy and knows his stuff.
Just call me LB. ![]() '71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads. |
#19 |
Old member
krue,
That's what I was saying. The drawing was wrong for the intended use. Not your drawing the first one posted. ![]() ![]() ![]()
#20 | |
Designated A-hole!
The drawing and the text don't agree.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" Last edited by krue; 10-15-2007 at 10:02 PM. |
#21 |
blood type; Retumbo
am I missing something here? from what I see you are still relying on the starter's pull-in and hold-in windings to operate the starter mounted solenoid. just placing another current limiting corrosion inviting switch into the mix doesn't make sense to me. (on the average you loose 0.2V per connection and then figure in the resistance of the extra wire length)
#22 |
Designated A-hole!
Gotcha. The drawing you showed in the last post kinda defeats the purpose to me. What I would like to find is a starter w/o the solenoid (kind like the furd ones) that would work on our trucks. With the remote soleniod you can still have the original solenoid to fail on you.
#23 |
Thanks again to everyone who responded. I'm going with Krue's suggestion. Seems to be the way the kits wire up.
#24 | |
Designated A-hole!
