10-16-2007, 07:40 PM | #1 |
The Original HotRod KnifeMaker
Anyone have vacuum problems with mild cam?
I had a mechanic tell me that I would need a vacuum booster if I went to even a fairly mild cam.........
True or bull? Thanks,
Dave 69 GMC SWB 2WD 454 Turbo 400 |
10-16-2007, 07:45 PM | #2 |
Re: Anyone have vacuum problems with mild cam?
Is 292 a radical cam?
It depends on what you have that runs off vacuum. Non-power brakes, manual transmission and dual plane intake let me run that with no problems. If you have power brakes, single plane manifold and an automatic without stall converter you may need a vacuum booster anyway. I don't really know what the cutoff is but with more info someone a lot smarter than me might be better able to guide you. EDIT: Oh, I also have 3.73 gears. That helps too. Last edited by 71tahoe; 10-16-2007 at 07:46 PM. |
10-16-2007, 07:46 PM | #3 |
aka TEX-TOY
I am about to put a booster on my truck.... Actually a Vacume Resivour...
1969 Chevy C10 SWB w/ disk brakes and soon to be lowered with spindles and springs!!!! Getting a paint job like a Army Chinook Helicopter!!!! HOOKERS RULE!! BRAND NEW WIFE BOUGHT IT FOR ME AS A WEDDING GIFT!!! SHE IS THE BOMB!!!!!! |
10-16-2007, 08:34 PM | #4 |
225 duration, 525+ lift...
stock power brake & automatic tranny ...no problems here.
- Jason If you can turn, Youre not going fast enough. Favorite caption: first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around.. ..back when men were men. |
10-16-2007, 10:10 PM | #5 |
If it IS a problem after the new cam is in...
What is the answer to low vacuum and how do you recognize it? My truck is a 69 GMC, 396, factory steel high-rise intake, th400 trans w/o kickdown, factory power brakes... The cam is a voodoo: Advertised Duration 262/ 268, Lift .530/ .542 . Thanks,
Dave 69 GMC SWB 2WD 454 Turbo 400 Last edited by WinDancer; 10-16-2007 at 10:14 PM. |
10-16-2007, 10:14 PM | #6 |
Bad hesitation/stumble on take off. Probably have a lot of trouble idling.
