Stepside Fanatic!
HELP bolting on 350 fuel pump!!
What's the trick? I seem to need three hands to do this! The pressure on the pump arm makes it so the dang thing keeps pushing off to one side as I try to tighten the bolts. I can barely reach under there anyhow, and can't quite seem to get it. Any ideas?
glamoros piece o' lowlife
Re: HELP bolting on 350 fuel pump!!
manually turn the engine over till the pump lobe on the cam causes the actuating rod to go as inside as possible, that should reduce force on pump lever enough to allow you to bolt it down. Don't really remember mine being a problem, but then again I put it on with the engine out of the truck..
The more I drink, the more I drink, the more I drink... diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express |
#3 | |
Wishin' I had more money!
Guess I'll let you know soon though. Gotta replace the gasket down there so it's gotta come off again |
yeller
Do what Ivan said...then stick a dap of grease on the pushrod and slide it in as far as possible. The grease will hold the pushrod up while you install the pump.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
Droppin' It Like It's Hot!
On the front side of the block there is a bolt that you can remove and place a longer bolt or a rod in to the hole to hold the fuel pump rod in place. Then you can stick the fuel pump in without having to worry about the rod moving...
Robert
Life Member RIP CAROL JANICE HARTMAN. BELOVED MOTHER. 01/04/53 - 03/05/09 1969 ![]() Norwood, MO 2007 Big Sandy, TN 2008 Had nothing to do with the forklift! Kirkwood, MO (Midwest Meet 2009) Midwest All Truck Nationals, KCMO - 2008 - 2009 - 2010 - 2012 - 2014 SUPPORT THE SITE HERE! Last edited by bobbo; 10-19-2007 at 07:08 AM. |
#6 | |
Oscar '72 Shortbed Fleetside '95 Jimmy 4X4 '69 GMC Custom Camper |
That's funny but so very true.
Robert
Life Member RIP CAROL JANICE HARTMAN. BELOVED MOTHER. 01/04/53 - 03/05/09 1969 ![]() Norwood, MO 2007 Big Sandy, TN 2008 Had nothing to do with the forklift! Kirkwood, MO (Midwest Meet 2009) Midwest All Truck Nationals, KCMO - 2008 - 2009 - 2010 - 2012 - 2014 SUPPORT THE SITE HERE! |
The Crazy Machanic
i dont know if this is to late but to help out in makeing the rod stay in place i would turn the engine tell the rod was as far in as i could. like stated before then take some grease and put it on the end of the rod and put it in. the grease is thick enough to hold it in place long enough and after the engine is ran the grease just melts down to mix with the oil so no harm will come from it.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day) ![]() * 1970 chevelle 2dr sedan Latest update June 24 2007. ![]() *1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad) ![]() newest additions 1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in and a 79 c60 trash truck um no idea i have one ![]() |
#9 | |
ever heard of bending the fuel pump push rod doing that??? seen it happen several times...thats why i've always stuck with the grease trick
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you." '84 chevy half ton short box 2wd, 67,000 actual miles ![]() '03 chevy 1500 HD crew cab 4x4 standard box, 6.0L ![]() ![]() ![]() |
Addicted to Chevy
i have done the bolt trick many times and never had a problem at all... you would have to really bear down on the bolt to bend it i would think! youre just supposed to apply enough friction to keep it from sliding down. it is a solid piece of steel, and fairly short at that, so i find it hard to believe that it is bending
Parts and more parts
I ensure that the rod is able to be pushed as far up into the block as possible, by turning the motor over until the back of the lobe is against the rod end, then I use a long heavy feeler gauge (with a bend close to the outer end) to hold the rod up in place and then slide the pump arm under the rod. once under it, the pump can be aligned with the bolt holes and the bolts started.
I agree. As long as you don't use air tools to tighten the longer bolt you shouldn't have any problems. Just tighten enough to hold the rod snug and remember to remove it and install the shorter one afterwards.
Robert
