Old 10-20-2007, 02:04 AM   #1
68SHORTBOX
68SHORTBOX's Avatar
Question 68 Tilt column Install
Got the new column preped and painted it. Made the mod for the netural safety switch. Easy mod when column is apart. The 72 column has a 36 spline shaft, are you using the center shaft from the van to attach it to the steering box The 68 shaft is one piece all the way to the slip sleeve with no splined coupling to attached it to the column any help here would be great.
68SHORTBOX is offline   Reply With Quote
Old 10-20-2007, 03:53 AM   #2
JimKshortstep4x4
Re: 68 Tilt column Install
The shaft extension for the 69 up trucks should work well for you but you will need to collapse it a bit.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 10-20-2007, 10:47 AM   #3
Ditto!! You just need the rest of a later 2-pc column.Doesn`t need to be tilt.
Old 10-20-2007, 03:14 PM   #4
68SHORTBOX
68SHORTBOX's Avatar
Thanks guys, I knew that somthing would fit but just didn't know what to look for. Thanks for the help
