cowl screen
hey does anyone have a screen or know where to buy a screen of some sort to put in the cowl? i just see this area getting full of junk that will cause grief later on. thanks. btw, pics are always helpful and appreciated.
70 LWB, 350/350 A/C, P/S, 3 Tone Paint (white cap, primer gray with black guide coat) |
Re: cowl screen
u can get some stainless expanded metal , that would look sweet , there is alot of different sizes and you can get it from a local metal shop
Re: cowl screen
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
I am a Referee of life.
Re: cowl screen
The board vendors carry premade ones.You just remove the cowl and bolt them on.I used twist ties off of bread loaves to hold mine to the cowl then started the bolts/screws and removed the ties.They come in stainless or black powdercoat.I got mine from Tim Christian but I'm sure most vendors carry them
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Re: cowl screen
Aren`t those things like $50?They are a great idea,but should be more affordable,I think.Especially when something could be made for dirt cheap.I guess when you have just one truck it doesn`t seem so bad.
Active Member
![]() Join Date: Jul 2007
Re: cowl screen
This is what I did on mine. I wanted something I didn't have to spend a lot of time with. Bought it at Lowes Lumber yard. Cheap and easy to install and cut.
There are a log of good ideas from the other guys here also. |
Re: cowl screen
Frizzle Fry just made a thread about this very topic.
it's located HERE
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill |
Old member
Re: cowl screen
Go to Lowes and buy window screen for home windows. You can buy it in differant colors to as long as it's black and gray. It keeps almost all debri out even pine needles.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Out of the carpool lane.
Re: cowl screen
I just glued my fiberglass window screen in using epoxy. It works great and hardly noticeable.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
Re: cowl screen
thanks guys, so stupid question....to remove the cowl, i will just have to raise the hood and remove the wipers then unbolt it, correct? or is there something i am missing? thanks again.
Re: cowl screen
That's pretty much it.
Old member
Re: cowl screen
Open the doors and take the 2 9/16" bolts out of the side of the cowl. There are two more on top. Then take wiper's off and all the S/S screws along the rubber strip for the motor. There are some more up by the wiper's also.
Re: cowl screen
That gutter screen and expanded metal leaves too big of a hole to catch everything and snags leaves.I do like Andy and use window screen.
Re: cowl screen
I also went with the fibreglass screen. I used silicon to glue it to the underside of the cowel. I saw a post awhile back where another member had done the same except they use HM glue. I couldn't get the hot melt to stick.
The picture doesn't do it justice. It looks and works great! ![]() |
#15 | |
Active Member
Re: cowl screen
I used a window screening several years ago and it worked will except that it tended to clog up with dust. I guess it depends on where your location is as to what type of screening works best... |
