New Member
Starting Point
I have a 1967 Chevy C10 Long bed. I'm now in a postion to start my restore of this vehicle. My question is Where do I start. Do I start inside and work my way out to the body. I'm just not to sure. I was curious where each one of you started on your vehicles. Thank you for your time.
Re: Starting Point
I just went through the same thing a few weeks ago. I started my first resto. What i did was get the bed off first. Then took apart the front clip (front fenders, rad. support, etc). Then i unhooked anything from the cab to the engine and tranny and pulled both out as a unit. After that i removed the doors (i drilled 2 small holes in each hinge of my doors just large enough to get a finish nail or something like that to help with putting the doors back on and getting them aligned since they were before i removed them. Then i started inside the cab and started the gutting process. Once that is complete i removed the cab. Then front end suspension and and rear end. Make sure you have plenty of baggies and sharpies to mark everything you remove and take lots of pics. Good luck.
Re: Starting Point
befor you tear it down i would sugest driving it as much as possableif it is an option. this will tell you what you like and dislike to help you put togather a plan for your build
common sense isn't so common anymore |
#4 | |
Luv the Crewcabs
Re: Starting Point
Good Luck, Rick
55 Nomad 52 Willys Truck 67 Stepper 67 Fleet 68 Wrecker 68 Suburban 76 Crewcab 79 Gmc Dumptruck 84 Blazer 86 Crewcab Stepside 87 Iroc 89 GMC Plow Truck 91 Camaro Vert 96 Z71 Stepsde |
I am a Referee of life.
Re: Starting Point
Start with a tank of gas and a notebook.Then save up several thousand dollars.Buy a digital camera.Buy stock in the baggie company.Then as stated drive it until you have an idea of what you want to end up with.Use the notebook to take notes.Then tear the truck apart spend all the money you saved and about 30-50% more.Then wait until you have enough money to finish.
Well anyway that's what most wind up doing.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" Last edited by PanelDeland; 10-21-2007 at 05:40 PM. |
Old member
Re: Starting Point
Start with the motor and transmission. Get that all done and then you can go about the rest when time permits. This way you can drive it as you go.
Now if it's going to include the frame being all done then start where ever you want and have plenty of storage room and baggies as stated before. If you plan on a full redo then just strip it totally down and start from the ground up. Front end Rear End Frame motor, trans Bed or cab front clip You can't drive it until the bottom of the truck is done anyway so why bother with the interoir until the frame is rolling again. This is my way of thinking anyway.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
New Member
Re: Starting Point
Thank you all for your input. I'm looking foreward to a great build.
