10-27-2007, 08:50 AM | #1 |
500hp
so this is my first truck build and its an 86 swb. i just want to know what 500hp really feels like in these things....someone explain. my combo should be making about 500hp at the crank plus 125 shot for the track to give it 500hp at the wheels and alot of tq. oh yeah a 6sp manual and fully locked 4:10 gears
.....whats it feel like |
10-27-2007, 10:10 AM | #2 |
Happy to be here
Re: 500hp
Go drive a new Corvette, or Viper and you will know...
10-27-2007, 10:14 AM | #3 |
Trucks N Tranzams
Re: 500hp
Make sure that you got the drivetrain to back it up, including brakes.
Don '68 Chevy LB 383 TH400/GV/373 posi '56 Chevy 4WD SWB '64 Chevy short stepside '79 Trans Am 455/TH2004R/12blt/4whldisc 95 Kia (Wifes car) 2002 S-10 extended cab pickup "God punishes small sins immediately" |
10-27-2007, 10:56 AM | #4 |
www.73-87chevytrucks.com
Re: 500hp
With a fully locked 4.10 gearset it is going to feel dangerous. I am hoping you mean a differential and not a spool. With that much power, you will be spinning the tires off with the stock leaf setup.
As for how it feels, that would be hard to describe, maybe over powered?
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
10-27-2007, 11:11 AM | #5 |
Re: 500hp
500 hp in a leaf spring truck is pretty harsh -- if it ever attempted to hook, the axle wrap would be severe and the tires would spin for days. That new Viper motored Dodge - the SRT-10 -- is only good for low 14's, high 13's in the 1/4 because of things like this
Most people with engines like that in these trucks just use them for cruising and rarely pour the coals to it-- probably would be a wise idea to hold off on the spray until you are out of the hole too--- but there is a company that makes custom slapper bars for these that tuck out of the way where you cant see them from the side, and work well I am assuming 500 corrected hp though, --- 500 uncorrected at the crank is more like 425 at the rear wheels, and that is a bit more "manageable". You didnt mention it, but is this a small block or a big block? There is a huge difference in torque too, between the two that will mean more in a seat-of-the-pants measurement than the net hp reading (big blocks feel faster, even if they're not--- i dont know the science behind that, but its true) Last edited by streetstar; 10-27-2007 at 11:17 AM. |
10-27-2007, 11:16 AM | #6 |
Re: 500hp
If it is locked it will definitly have wheel hop.
If you really want it to hook, you need these: http://store.73-87chevytrucks.com/me...gory_Code=SUSP
10-27-2007, 04:09 PM | #7 | |
Garage Queen Material
Re: 500hp
how would these caltracs compare to a decently setup 4-link and coilovers? the caltracs are MUCH cheaper and i had totally forgot about them until you posted them. i want to go with a 4link setup next year, but if the caltracs will hookup just as well and save me money... |
10-27-2007, 04:28 PM | #8 | |
a fool with no money
Re: 500hp
with 4 links / ladder bars and coil-overs, you just about have infinite adjustability, but with the Caltracs it's very limited. For a mean Streeter I would go with the Caltracs everytime. these are a bolt-on installation and thats a h3ll of a lot easier/cheaper than 4link/ladder set-ups!
Basicly stock 83 SWB with a few Bolt-ons before, during and still during http://photobucket.com/albums/y251/moostifer/truck/ http://photobucket.com/albums/y251/moostifer/motor/ |
10-27-2007, 12:33 PM | #9 |
Re: 500hp
What's your combo? 500HP at the FW is often discussed, seldom seen
10-27-2007, 03:36 PM | #10 | |
Re: 500hp
seriuosly (did I spell that right?) with these trucks and speed... it's all about traction, trust me... been there, broke that. Without the right suspension, all your efforts will go up in smoke (tire smoke)
10-27-2007, 04:20 PM | #11 |
Re: 500hp
and like CaptKaos said...
Caltracs are worth their weight in gold! I know of several cars and a couple of trucks that the only suspension mod was a set of Caltracs and some good shocks and are getting 1.50's at the 60 ft mark.
10-27-2007, 05:26 PM | #12 |
Re: 500hp
You can get sub 2.0 60ft with these easily. They are limited in adjustability, but they work. We are putting a set on my brother 2000 Silverado that is turbo'd.
10-27-2007, 06:46 PM | #13 |
Re: 500hp
cool - those Cal-tracs are exactly what i was talking about when i said "custom slapper bars", but i forgot the name-------
I need a set of those too |
10-28-2007, 06:44 AM | #14 |
Re: 500hp
here is the set up. first off i have a fully boxed frame with a custom made four link and coil overs. i have a fully built ford 9" rear with a lock rite locker and 4:10 gears. the rear is narrowed with 33 spline moser axels. its going to have a fully built t56 tranny with aluminum fly wheel and driveline.
now in front of all that is a fully built 10.6:1 small block 388 stroker. everything is blueprinted and port matched. forged internals when the project is all done i should be seeing about 500-520 hp at the crank. then on trck days im going to put 100hp nos shot in it. did i mention its tubbed and im running the mickey thompson s/r sportsman radials for the street. 29x15x20 on coys 20x14 in the rear and 18x8 up front |
10-28-2007, 09:39 AM | #15 | |
Re: 500hp
- Greg |
10-28-2007, 10:10 AM | #16 | |
Re: 500hp
If it hooks well, I would say low 12's to mid 11's... 10's in these trucks are pretty hard to achieve with a street/strip set-up planning on running a different tire at the strip? let me know how those radials work out, my sportsman pros are shyte for cruisin... and like that guy said....
Basicly stock 83 SWB with a few Bolt-ons before, during and still during http://photobucket.com/albums/y251/moostifer/truck/ http://photobucket.com/albums/y251/moostifer/motor/ Last edited by Moostifer; 10-28-2007 at 10:11 AM. |
10-28-2007, 11:10 AM | #17 |
Re: 500hp
Sounds like an awesome setup! Pics would be good As for how 500 hp feels...let my brother finish breaking in the engine on his supercharged Shelby GT and I'll let you know.
10-28-2007, 11:01 AM | #18 |
yeller
Re: 500hp
Cal-tracs on my '73...can't wait to try them out. The install is super easy, and they have an awesome street/strip rep for their performance. Very well built too.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
10-28-2007, 10:07 PM | #19 |
Re: 500hp
i will try and get some pics soon, its all in parts now, but i will see what i can do.
how does $4800 sound for the whole motor. not bad i think. i was hoping to hit the 11's on this set up, but who knows. yeah i will be running slicks at the track prolly a 29x16x15 or something like that. im hoping i will be able to get tire spin at close to 50mph, im gonna have to use some crappy tires for awhile to get the burnouts out of my system. i dont want to burn out $400's per tire |
11-28-2007, 02:29 PM | #20 | |
Parts and more parts
Re: 500hp
I don't have 500 HP, but my 84 SWB with a 385 stroker motor is pushing about 400 at the crank and it can be hard on the rear end parts, if I want it to be. I had to pay a little more than the $4800.00 [rice for the motor work and parts. |
10-28-2007, 11:03 PM | #21 |
>130dB Moderator
Re: 500hp
I drove a new Z06 a little while back and let me tell you that it's dam scary at first. Its the kind of power you can get used to though.
It's going to pull hard if you can keep the wheels planted...
Living Life @ 130dB LED Tail Light Conversion; How-to Friend. Father. Brother. RIP El Jay ------------------------------------------------------------------------------------------------------------------------- CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum. |
10-29-2007, 01:54 PM | #22 |
Re: 500hp
well it sounds like you have all the candy you need on the chassis ---- that kind of horsepower is on the ragged edge for most small blocks though--- i cant imagine it being much fun on the street (big c am, loose converters, no vacuum, etc etc)
10-29-2007, 05:05 PM | #23 |
>130dB Moderator
Re: 500hp
Are you kidding? There are guys making tons more power than that with small blocks.
10-29-2007, 09:20 PM | #24 | |
Re: 500hp
Not a lot do it naturally aspirated--- and not with most 383 or 406 based projects ---- 500-550 hp is quite a bit and is at the ceiling for most small block power combos . If you have the bottom end to back it up, sure, the sky is the limit with a turbo motor, a blower or nitrous . A lot of guys make 500 hp in the garage with a cold one in their hand benchracing with their buddies, but then turn around and run 13's at the track. |
10-30-2007, 06:02 AM | #25 |
>130dB Moderator
Re: 500hp
That's odd, there was another post just after your last one that said that 500hp was the limit on a small block. Can't remember who posted it though.
I agree whole heartedly with you though. Forced induction is pretty much neccessary after 500 n/a hp
