67 Chevy Stepside
will 73 door panels fit on a 79 door
will 73 door panels fit on a 79 doors thanks.
1967 Chevy stepside 1976 BIG DOOLEY 454 turbo 400 4:11 |
![]() Join Date: Mar 2005
Re: will 73 door panels fit on a 79 door
Yes
The 79 door has a longer window crank shaft, different door handle , and extra mounting holes that wont be covered by a 74 door pane . Frank
Born and proudly residing in a Red State ! |
f.monroe is right I have the problem of using the early window winder mechanism with the 79 interior trim because my factory 79 one broke and I could only get the earlier version. My window winder sits on the dash because the shaft is to short to get the winder to stay on.
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
If you want it to look correct the answer is no.
If you don't care about the 77-91 stalk sticking out 2" past the doorpanel, and the 4 holes at the bottom showing, it will bolt on.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
67 Chevy Stepside
thanks
