![]() Join Date: Jan 2003
What size bolts do you use in your Blazer top?
Question for all you blazer guys. I got a new top for my blazer and was wondering what size bolts typically go in these. My old blazer top used fine thread 3/8 and the new top looks to be a 5/16 course thread, but don't screw in real easily??? Any help or suggestions would be greatly appreciated...
Thanks Dana
1972 Cheyenne K-30 6"lift {502 PROJECT} 1972 Cheyenne K-30 8"lift 454 450hp {Ol'Blue} 1972 Cheyenne K-20 Custom Stretch 6" lift 454 1972 Custom Deluxe K-20 4" lift 2007 GMC Crew Cab Diesel 6"lift {The Tow Rig 2017 Ford F-350 Crew Cab 6.7 6"lift (Wife's) 1977 El Camino SS Grandpa baught new 1986 K-30 Crew Cab 502 1955 Chevy 2-Door gasser 454 550hp{project} 1956 Chevy Bel-Air 2-Door hardtop 572 700hp 1979 Ford F-350 All Original 4x4 (Wife's) |
Keepin it runnin!
Re: What size bolts do you use in your Blazer top?
My 70 has the 3/8" SAE thread. Whatever you do IMHO make sure you put antiseize on them before installing!
Frank
1970 K-5 4X4 Blazer ![]() 1970 K-20 4X4 Long Bed ![]() "Liberty Means Responsibility, that is why most men dread it" |
Looks like mine (72) are 5/16 coarse. I'd recommend you use flat washers under the heads of the bolts to protect the fiberglass.
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Here are the bolts used for my 71,single walled top.
![]() ![]() I used stainless fasteners for the bedrail. ![]() ![]() ![]() ![]() ![]() ![]() ![]()
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE Last edited by augie; 04-09-2011 at 03:11 PM. |
its all about the +6 inches
slightly off topic, the single wall tops, where the bolts go down, is the bed side threaded?
This will be marked for FAQ. |
Keepin it runnin!
My Parts Blazer is a 72 single wall and no the bed is not. Nuts & washers are used.
My bedrail is threaded.
Is it factory?...who knows. I blew up the pic so you could see that every other hole is threaded.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
![]() Join Date: May 2006
My '72 has both holes, single and double. The ones that bolt from the top are attached with nut plates that can slide a little for adjustment
Member #1049
All of my Blazers have hex head 5/16 coarse thread bolts, they look almost like a fender bolt but have a flanged head.. (built in washer)
| Bookmarks |
