Old 10-30-2007, 11:42 PM   #1
WinDancer
The Original HotRod KnifeMaker
WinDancer's Avatar
Question What, and how much time, is involved in a bed swap?
How much time does it take to swap a bed on our trucks?
What all is involved?
How muck fussing with wiring?
It seems pretty straight forward but I thought I should ask BEFORE I get started?
Thanks,
Dave
Dave
69 GMC SWB 2WD 454 Turbo 400
WinDancer is offline   Reply With Quote
Old 10-31-2007, 04:08 AM   #2
wibilly
wibilly's Avatar
Re: What, and how much time, is involved in a bed swap?
the wiring harness just unplugs, a ground strap or two and eight bolts.providing the bolts are not rusted to bad and don't require cutting or grinding off you'll be ready to lift it off in a half hour maby a little longer if you run in to some stubbern bolts or a 12 pack
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 10-31-2007, 04:46 AM   #3
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Not mention you need to have the bar-b-que going for the 4 guys that are going to do the lifting...and of course...
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 10-31-2007, 10:59 AM   #4
stllookn
Saving 1 truck at a time!
stllookn's Avatar
If it has been on there longer than about a year...have an oxy/acet ready for those stubborn bolts/nuts. You might just as well get new rubber mount bushings too, while you are at it. Don't for get the ground straps...and like 71redcheyenne said...those 4 burly guys fueled with beef and brew...LOL!
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 10-31-2007, 11:08 AM   #5
djracer
djracer's Avatar
I've never had much trouble just spray pb blaster on the bolts and use a good impact!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 10-31-2007, 11:40 AM   #6
cdowns
cdowns's Avatar
save the beer money just use engine crane an easy one man job
Old 10-31-2007, 11:40 AM   #7
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
The bolts are those square hole carriage bolts, so no power tools, or they will just spin. Use a pair of vice grips, so you can keep down pressure/tension on the bolt as you turn it. Most are not rusted bad and come off easy.
No rubber pads on factory beds. You can add them, but I don't know what they are supposed to do. Maybe quieter?
PICKMUP is offline   Reply With Quote
