Old 10-31-2007, 01:09 PM   #1
wreckless_68
tach question
im looking in to putting a tach into my 68 2wd short wide pick up. i want a stock in dash guage. i hate the looks of those on the colum. what do i need to consider for putting in a tach in a dash that came stock with out one. cost is an issue so the fewer pieces i need to replace the better. Any help would be much appriciated. thanks.
Wreckless_68
wreckless for life
wreckless_68 is offline   Reply With Quote
Old 10-31-2007, 01:17 PM   #2
clos69
Its Topless Season!!!!
clos69's Avatar
Re: tach question
check the FAQ on tach...there are a couple good threads that talk about using camaro tachs from the mid 70's to mid 80's...on our trucks
clos69 is offline   Reply With Quote
Old 10-31-2007, 01:41 PM   #3
70GMCer
70GMCer's Avatar
Re: tach question
I installed a Camaro tach. A lot cheaper than the original and almost looks the same.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 10-31-2007, 03:55 PM   #4
Andy4639
Old member
Andy4639's Avatar
Re: tach question
You can buy the tach and wiring harness and cut the back side of your dash to install it. You will need the printed circuit for the tach and new lens.
Buy a complete dash and then sale your's. The vendors here can set you up with everything you need.
Just depends on which way you choose to go.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
