Have a 350 out of a 76 GMC 1/2 Ton , can I use Rams horn Manifolds or will I need to use the stock 76's , Thanks
Fabricate till you "puke"
You need to use the rams horns, to install it in a 67-72.......or you can also use the rams horns on the 73 up, but the 73 up manifolds wont fit the earlier truck. Crazy AL
its all about the +6 inches
Yep, you'd end up having to hack the motor mount tower if you used the log manifolds.
The ramhorn deals flow better anyways. |
Thanks for all your Help . Now I jest have to find a set.
