11-01-2007, 11:39 PM | #1 |
4.3 into a 54
i have a 54 3100 i would like to do a ifs and i have a 1985 s10 with a 4.3 and a 10blt rear its also supercharged i would like to put this set up into my 54 what can i do can i use the rear in the 54? i know that a set of v8 mounts will hold the 4.3?right?i found a universial trans mount but what about front suspension?i would like to retain factory frame?????please help
11-02-2007, 12:05 PM | #2 |
polishing a turd
Re: 4.3 into a 54
what's wrong with the front suspension? do you want ifs?
it might be easier to swap the body onto the s10 frame, but you said you want to keep the original frame. is your s10 2wd or 4wd?
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512 53 buick special - straight 8 sled - blow through turbo 47 gmc - flatbed hot rod build 99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van' |
11-02-2007, 06:40 PM | #3 |
Re: 4.3 into a 54
2wd and i figure body fits frame to well but i want better handling
11-03-2007, 09:02 PM | #4 |
Re: 4.3 into a 54
i dunno about handling power but the 4wd s10 rear works very well, id suggest swapping the frames, it will give better handling being on the s10 chassis
