Old 11-02-2007, 08:01 PM   #1
davidh
davidh's Avatar
anyone running 6cy and 3.07 gears?
I have two 5lug rear ends, one is a 3.07 and other is a 3.73. truck has a 292 and 3speed. I was curious if anyone is running higher gears with their 6 cyl inliners and if they liked or did not. thanks
Even the nicest dodge-chrysler is only 2years away from being parked outside of Section 8 housing.
davidh is offline   Reply With Quote
Old 11-02-2007, 08:09 PM   #2
bad6772
Official Site Guitar Shredder
bad6772's Avatar
Re: anyone running 6cy and 3.07 gears?
im running a 3.42 with a mild 250 6cyl and a 3speed.... drives just fine...in town and on the highway... i run about 65 70 on the highway...and about 2900 or 3100 rpms at those speeds......
bad6772 is offline   Reply With Quote
Old 11-02-2007, 11:44 PM   #3
wibilly
wibilly's Avatar
i think with the torque of a 292 3.07's would be great. if your not doing a lot of heavy towing in hilly areas
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 11-03-2007, 02:16 AM   #4
Brad
Out of the carpool lane.
Brad's Avatar
I tried 3.08's with my 250 and I really didn't like it- and don't recommend it for 250's especially if you actually work the truck. However, if your 292 isn't tired and worn, it may work ok with the extra cubes and torque. I think it actually might the more I think about it, as long as you aren't working the truck all the time.
I had to use alot more clutch with my 250 and just hope you don't get stuck in traffic on a hill!
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 11-03-2007, 07:24 AM   #5
Cars have 3.07s and trucks have 3.08s.They are tall far pulling off with a 3spd,which is the problem.A lower 1st will be desired.If you have a torquey 292 then it will be better.But,I just never liked the 1st gear in a 3spd for anything.The only truck I kept a 3spd in was a shortbed`68 with a 396.It rolled right out of the hole with that high 1st.I would have put a 4spd car trans in,but wanted it kept original.
Old 11-03-2007, 09:26 AM   #6
chris71
chris71's Avatar
i had a 250 with 3.73's, i agree with the other guys, 3.73's good for off the line and around town, but on the highway not so good, i have 28" tires (not huge) and felt like the motor was topping out at like 65 mph. something to think about if you do a lot of highway driving or want to go 80.
'55 3100 2nd series short-bed stepside
'70 Corvette coupe stingray
'71 Chevelle 2-dr coupe SS clone
'71 C10 long-bed fleetside
'83 long-haired brunette wife
chris71 is offline   Reply With Quote
Old 11-03-2007, 09:32 AM   #7
67ChevyRedneck
67ChevyRedneck's Avatar
Same here. That's why I went to a 350 and 700R4. It was almost hammer down to get it past 65 and the engine was screaming. I had a 250, 3 spd, and 3.73.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 11-03-2007, 12:33 PM   #8
davidh
davidh's Avatar
maybe if I ran 30" all terrains instead of standard 28" tires and the 3.73's I'd have a tad more highway. This truck will be used to work some but also want to go down the highways at 65mph.
Old 11-03-2007, 11:58 AM   #9
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I ran a 292 in my truck for a good while with the 3.08 gear. The 292 pulled it just fine without complaint. The 350 in it now doesn't pull much better as a matter of fact. Don't underestimate the 292's torque.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 11-03-2007, 12:47 PM   #10
BWisdom
New Member
BWisdom's Avatar
I have a granny 4-spd with 292. I am thinking of installing a caddy rearend, disk brake with large 5-bolt pattern (like the half-tons) & correct width. The gear ratio is 2.32. How do you think this combo will work...granny is very low for the 4.11 rear now in the truck but seems like the 2.32 take-off should work...what are your thoughts?
BWisdom is offline   Reply With Quote
Old 11-03-2007, 02:24 PM   #11
davidh
davidh's Avatar
I think there is too much gap between the granny low and 1st gear for that to be feasable.
Old 11-03-2007, 01:10 PM   #12
The 82 I had was a 250 with T350 and 2.75 rear. Off the line not great, but as a daily runner, in town and freeway, it held its own. Just don't expect it to pull a house off the line or go much above 70 on anthing other than flatland. BTW, it did not help MPG with it being that high a gear either.
Old 11-03-2007, 01:13 PM   #13
67ChevyRedneck
There comes a point to where you get too high a gear and you're too low in the engines preferred rpm power band. Most GM motors are happy between 1800 and 2500 rpm.
Jesse James
Project "On a Dime"
Old 11-03-2007, 01:50 PM   #14
BCOWANWHEELS
what about a 292, sm465 and 3.08 gears, 28" tires combo. think this is good for a work truck?
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 11-03-2007, 02:29 PM   #15
davidh
davidh's Avatar
that trans still has 4th gear as the same as a 3 speed, 1:1 ratio so only adding a granny gear
Old 11-03-2007, 01:11 PM   #16
67ChevyRedneck
Your truck would probably be "weak" from the time you shift to 3rd until about 60mph when the rpms get back to 16-1700. Assuming a 29 inch tire. 2.32 is too high for a truck with large tires and weighs 3500-4000 lbs. That's my opinion.
Jesse James
Project "On a Dime"
Old 11-03-2007, 06:18 PM   #17
BCOWANWHEELS
yes thats what i,am saying. with the 3.08 r&p gear it is had to pull out loaded so if you have the super low 1st. gear in the sm465 then all should be good right ?
