10-06-2002, 10:51 PM | #1 |
New project - 1970 LWB
Went and helped a friend and his son start tearing apart a 70 that they bought in NE for $350. Eventual plans are for a 4/2 drop, beefy 350/th350 combo, painted midnight blue with yellow details. A couple of wierd things that I hadn't seen before on my 71 or a couple of 72's.
Like this power converter?
------------------------------------------------ I say it's only money, my wife says it's only a truck.... '71 C10 Deluxe, factory ac, ps, pb, should be done by 2102 Longmont, CO husker95@hotmail.com |
10-06-2002, 10:52 PM | #2 |
and hadn't seen leaf springs on any 67-72's yet...
------------------------------------------------ I say it's only money, my wife says it's only a truck.... '71 C10 Deluxe, factory ac, ps, pb, should be done by 2102 Longmont, CO husker95@hotmail.com Last edited by colohusker; 10-06-2002 at 10:55 PM. |
10-06-2002, 10:54 PM | #3 |
or a carrier bearing of this style....
Basically got the bed off, grille off, and front clip ready to come off, next weekend we'll finish the clip, and pull the cab off. Got inspired by the pics of the powder coated frame, so that's what they want to do with it next month....I'll keep posting pics, and I'm sure we'll have questions so stay tuned....
10-06-2002, 11:16 PM | #4 |
Transcendental Trucker
Quite the truck you've got there..
The power converter looks like something the owner added, though it may have been a dealer option. Leaf springs were an option, and all 1 tons were leaf sprung as well. The carrier bearing is the heavier duty one, put with big blocks or TH400's or some combination thereof.. not sure exactly.
Patrick Sullivan | sullivan@oregoncoast.com Rockaway Beach, Oregon 1972 Chevy Cheyenne C-20 1998 Dodge Dakota 4x4 So, fill to me the parting glass And drink a health whate'er befalls... Then gently rise and softly call Goodnight and joy be to you all! |
10-06-2002, 11:20 PM | #5 |
Yep, knew leaf's were available, just hadn't seen one. The option list says 350/TH350, so don't know why the heaver carrier is on there, possibly due to the leaf's. I think the power converter was a dealer installed, doesn't show on the option list, but the wiring looks better than an owner installed job.
10-06-2002, 11:29 PM | #6 |
its all about the +6 inches
I have had the one ton Longhorn and a 3/4 ton Longhorn (which is a one ton in cognito) and have NEVER seen a carrier bearing that looked like that.
That looks like a cheap autozone (or other parts house) replacement to me. |
10-07-2002, 01:10 AM | #7 |
I've never actually seen one like that on a truck, either.. but it sure looks sturdier than the funky I-beam style they normally have.
10-07-2002, 09:48 AM | #8 |
67-72 Addict!
I thought dubie had that power switch on his truck.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
10-07-2002, 05:19 PM | #9 |
i got that bearing on my truck and its a 3/4 ton w a th 350 trans i belive it to be stock
will postpic if u want?
1986 c-10 swb 5/7 drop 20'' coys 1958 belair 2door |
10-07-2002, 05:43 PM | #10 |
Almost Satisfied
colohusker,
Let me know if I can answer any questions for you guys as you go. I know there are a lot more knowledgeable guys on this board than me, but I am just now putting mine back together so I may be able to help. It sure is fun once everything is cleaned up and powder coated. I like working with clean parts much better I found out. Where do you live in CO? I use to race MX at Longmont. At the Berthoud track there on 1-25. I think Longmont is close to that...or is Longmont just North of Denver??? It has been a few years...
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
10-07-2002, 06:07 PM | #11 |
1971 Stepside - Yep, can't wait until we're at that point, where everything is clean! Longmont is about 8 miles south of Berthoud, and I used to race at that track when I was growing up in Denver. Been trying to talk my wife into letting me get the boys a couple of bikes to race up there, but so far no luck!
By the way, your powder coating is what has inspired my friend and his son to strip everything down and do the same thing, just in different colors. I'm sure we'll have tons of questions for everyone. special70 gmc and longhornmail - As far as the carrier bearing, I think it came stock, since the crossmember is different as well from my 71.
10-07-2002, 07:43 PM | #12 |
member #16
My 70 short bed came with the same carrier bearing, had 402 th400 when new.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
10-07-2002, 08:47 PM | #13 |
computer illiterate
i had a 72 3/4 ton with the same bearing.
72 2wd blazer 72 swb 4x4 |
