Turning radius/ratio
i have a 1970 k20 closed knuckle front end; how can i improve the turning radius or can i?? will the open knuckle front end give better turning radius??
thanks,
1970 Chevy K20 Custom Camper 1996 Chevy Impala SS 2008 Chevy Avalanche LT3 2003 Honda Accord EX 2001 Hewes Redfisher 16 Fighting Lady Yellow Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=324118 |
Re: Turning radius/ratio
is the truck lifted up when its turned lock to lock does it hit the stops on the axle?
Earl 68 2500 4x4 GMC Burb |
there's nothing wrong with the mechanics that makes the truck turn (as far as i can tell, but that's not saying much) there's no grinding, no rubbing, nothing i can see or hear. i just think the truck's turning radius is horrible, it needs like 6 lanes to do a "U-turn" and was wondering if there is anything i can do about it.
thanks!!
if its turning all the way to the stops on the axle there isnt much you will be able to do. you may be able to turn the stops in some more so that it turns a little more but just make sure if you do it dosnt creat other clearence isues.
![]() Join Date: Feb 2000
An open knuckle axle will help your turning problem. My 69 has the closed knuckle and with the 35 x 12.5 tires it sure sucks to manuver in a parking lot! I can't tell you how much the open knuckle will help but you would also benefit from updating the axle as you will gain disk brakes!
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
I can personally tell you from experience, IF you adjust out the turn stop bolts, it places much more strain on the axle u-joints. When your wheels are turned sharp and you apply very much torque, the front axles and u-joints are very easy to destroy.
It's a whole lot tighter, I went to an open knuckle D44 on my 67 and now I can do a single U-turn on a wide 2-lane. You will wonder why you didn't do it sooner.
thanks all for all the good info!!
