Aluminum polish...
which brand of aluminum polish do you guys recommend?? i have a few items to polish that have some bad oxidation on them; i'm currently using mother's brand and some off brand wally world stuff and they seem to be about the same in quality; the process is really slow and it's killing me... i was just wondering if there is any other product that is better or if there is a better way in getting the shine back without me spending hours and hours scrubbing away!!
![]() thanks much!!
1970 Chevy K20 Custom Camper 1996 Chevy Impala SS 2008 Chevy Avalanche LT3 2003 Honda Accord EX 2001 Hewes Redfisher 16 Fighting Lady Yellow Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=324118 |
Re: Aluminum polish...
Nev-R-Dull wadding ... followed by Mother's ...
Official Site Guitar Shredder
Nothing to see here.....
![]() Join Date: Jun 2007
what knocking sound?
![]() Join Date: Feb 2005
First off, use a liquid polish not a paste. The paste types take twice as long. Secondly, if I were you, I would go to a local good-size truckstop. They tend to have the best stuff. I've been polishing wheels and tanks since I was a kid. I can polish all my wheels and tanks in about 2 hours with a good liquid polish. I can't really give a certain brand because some brands aren't sold all over the country. Hope this helps.
![]() kager
1968 C-10 1953 belair two-door post 1955 chevy 3600 big window 1950 studebaker starlite coupe 1968 Impala SS |
The trim is anodized and that has to come off first (try oven cleaner but don't let it sit--wipe in on then wash it off) then super fine steel wool and then polish. Grills, trim, etc. Use a power buffer with polish ----.
#7 | |
:( BYEBYE :(
![]() Join Date: Feb 2001
I've used Autosol. It's pricey, but I like it.
'72 Chevy Blazer |
theres some stuff called (X-treme) , it looks like cotton candy. its kind of hard to find , but all it takes is a really small piece to do a whole rim. it makes easy work of an oxidized wheel or tank. its not a liquid or paste its a wadding with an abrasive polishing compound in it. hope this helps.
Happy to be here
![]() Join Date: Mar 2000
I use Master-Formula. I have tried a LOT of different brands, and this has been the best so far. Take a look at the video here-Link
#11 | |
Parts and more parts
I have tried many different things and the fact of the matter, I have found that most are more hype than polish. Don't get me wrong, the liquids do take the dirt out of the metals and give a "Brighter" finish than they so called before condition, but if you want to really poish aluminum, then you have to go at it with a plan. First of all is the aluminum really dull and corroded, if so then start with any one of the liquids to get the dirt out of it OR do as I did, purchase some small buffing pads from Eastwoods (or Sears) and polish out the metal using the buffing compounds that you can get at many supply outlets (even Truck stops) Those truckers are always polishing their rims and fuel tanks. I use what is called a "RAZORBUFF" that is about 3" in diameter and real thin, attached to a die grinder. Using it along with a buffing compound the metal is taken to a shiney condition in a very short order. I did four 15" X 8" aluminum rims in about two hours (start to finish). That was starting from a really dull finish to a shiney completed condtion. To keep my rims finished I use Mothers aluminum polish, with a Mothers polishing ball to clean the metal and then finish with the Mothers Billet polish to give it a mirror shine. After the metal is cleaned, I seal the pores with a metal sealant from Wizards Products (there are other brands available---I found the Wizards to be easy to use and works great) to keep the dirt and water out of the metal. my wheels usually stay clean all summer. I use this on my billet Weld rims and my American Racing billets, also.
To prep aluminum to get it clean, if it is a coated or a standard aluminum piece, start by using a 600 grit wet-n-dry sand paper and then follow it up with a 1500 grit and then a 2500 grit paper. Use WD-40 as a wetting agent for the sandpaper. Once the finish is started the buffing then can happen with the compounds and a shine is not far away. I have built a lot of aluminum brackets for my projects out of standard aluminum strapping and pieces just that way and it works, with little effort---just time. |
Sierra Grande Club
I use jewelers rouge and a buffing wheel to get it shined up. I maintain the shine with Mothers Billet polish. Thats been the best so far.
I hear gibbs oil keep it form oxidizing with out making it oily. s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
How about zoop seal?
1972 Cheyenne 402 LWB 2005 Silverado X-Cab 5.3L 2004 John Deere L120 20HP B&S |
#15 |
i use jewelers rougue on a buffing wheel for stuff like valave covers, maintenance it with wenol, sometimes mothers, i love the wenol though, it will take out water and oxidation spots quick. i used zoops seal on my valave covers and since i am on the east coast and frequent the beach once and a while the salt in the air destroye the coating and oxidized my covers. not happy. stay away from it if they used salt on the roads in winter or live near the coast
'55 3100 2nd series short-bed stepside '70 Corvette coupe stingray '71 Chevelle 2-dr coupe SS clone '71 C10 long-bed fleetside '83 long-haired brunette wife |
#16 |
I use something called The Intimidator. I had to polish three sets of aluminum semi wheels (18 wheels total) and six fuel tanks this last summer. I used the Mother's Powerballs and it worked like a charm. I also tried using the Mothers Mag & Aluminum polish, but it did not work nearly as fast as this liquid polish. Oh, and I only used about 1 1/2 bottles which I didn't think was too bad.
http://www.theintimidatorpropolish.com/ |
#17 |
Flitz, and nothing else. ZOOP's Seal is good but very expensive.
Mike
Mike Redpath |
#18 |
Skinned knuckles
A lot of good ideas here! Here's my $.02. I've had an aluminum diamond plate truck tool box for about 9 years now and most of that was sitting outside neglected. After getting my Ranger last May, I was going to use it, but noticed how dull it was. I went to look at new boxes at Lowe's and found a bottle of aluminum polish to restore the new look. Thought I'd try it on the old box and found that if I use it with a buffing wheel on my polisher, then it brightens it right up. A little more work with a rag to clean up the black residue and it looked great! I haven't tried it on anything else yet, but I'll have to see how it works on my brothers wheels now that I think of it. The bottle says it's flammable which I thought was weird.. I can't remember the name of it right now, but its in a clear bottle with a silver label.
'72 C-10 longbox soon to be short step! '72 Chevelle (sold in January) ![]() '07 Sebring '01 Ranger (I've gotta long commute..) If you try to fail, and succeed, which have you done? My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=276904 |
#19 |
67-72 Addict!
This is the best I have ever used!. The purple is what I use:http://www.californiacustom.com/
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
#20 |
I with 70C10 100%. I have tried just about everthing that has been mentioned in this thread. BTW Xtreme company makes Never Dull. Most all alum polishes or cleaners are made from certain jewlers rougue and a type of vehicle to deliever it such as mineral spirits. When my wheels (Welds) were about 7 yrs old I got an award for the best ride on Weld Wheels at a show with 5000 trucks. My wheels are better looking than new ones and the guys that went to the Board Meet this summer can vouch for them and how easy it is, and how little of time I spend on them. California Customs.
#21 |
I will add that this is very good stuff too. I had a hard time deciding which was better, this stuff or California Customs. This is sorta like neverDull but comes in a cotton candy looking rope. About an inch of it will do one wheel. Bot products leave a chrome looking shine.
#22 | |
Happy to be here
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 11-07-2007 at 11:08 PM. |
#23 |
Happy to be here
Yeah, me too. My buddy Keith talked me in to it, but it turned out to be the best I have ever used. Even using it, I would spend 2-3 hours polishing my wheels front and back. I wasn't about to spend another hour putting the sealer on.
Now that I use the Power Ball on my wheels, I can do all 4 in about an hour. I might consider using the sealer now......maybe.
#24 |
I have never come across the Master Formula but like to try it. Maybe we should do some trading. I have some new bottles of the Purple.
#25 |
http://www.metalwax.comgo to the website metalwax.com this is the best stuff i have ever seen. it has all the directions for use with it. it works different than the rest of it but it works good.
