11-06-2007, 01:28 PM | #1 |
Drop spindle help needed, rubbing on upper CA
I put my 3 inch drop spindles on my frame today and the spindle and the lip of the upper control arm are hitting each other. Is there an adjustment I can make or am I going to have to hit it with the grinder? Is this a common thing?
11-06-2007, 01:32 PM | #2 |
Re: Drop spindle help needed, rubbing on upper CA
What brand spindles? I didn't have this problem with BellTech spindles on 2 different trucks. Did you replace the upper ball joints? Sure you got Left and Right correct?
- Greg |
11-06-2007, 01:59 PM | #3 |
The brand is DJM. I have them on the correct sides. I started off with a frame and have replaced every bushing, ball joint, and soon to be tie rod ends. I hope I do not have the wrong spindles. I have the spindles with the 1.25 rotor, and the correct rotor.
11-06-2007, 02:18 PM | #4 |
3DrDwn--the 'burb not the band
what's going on with the steering stop? on some spindles it's cast and some I've seen it's threaded like a bolt into the casting. If threaded you can back it out some. It's a trade-off with spindles that you'll lose some turn radius.
Did you trim the tab for the stop off the LCA? I know a few people who have made that mistake when cutting off the factory bump stop. as a last resort I've also had to grind the lip most recently with a set of Chassis Tech Spindles on an '84 burb. Josh |
11-06-2007, 02:36 PM | #5 |
I have not adjusted anything else on the truck as this is as far as I have gotten in putting it back together. When I turn the actual wheel to the front, sending the spindle in towards the motor, I have no clearance issues. I run into a problem when I turn the wheel back into the frame. I just went out and took another look at it and I noticed that the upper control arm bump stop is bottomed out on the cross Member. I wonder if I got the rest of the suspension on it and got if off of jack stands it would allow the upper control arm to articulate up eliminating this clearance issue.
11-06-2007, 08:13 PM | #6 |
Happy to be here
I just re-read this part of your post. Yes, if you "load" the suspension correctly it will no longer hit the upper control arm. It will "probably" hit the lower control arm if you are running 15x8's.
11-06-2007, 10:09 PM | #7 |
The thing that is confusing me is that I do not have any wheels on the truck, and the upper control arm lip is hitting the drop spindle.
11-06-2007, 08:11 PM | #8 |
Happy to be here
What size wheels are you running? If you are running 15x8's then they are definitely going to hit at full lock. It's seems weird that it's the upper control arm. Usually it hit the lower arm. Normally you have to remove the lip back to the shock mount to prevent it from grinding.
If you do remove the lip I suggest you make a boxing plate for the bottom of the arm. I have seen them crack. You know if you run 17" or bigger wheels it will resolve this issue.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 11-06-2007 at 08:15 PM. |
11-06-2007, 11:11 PM | #9 |
Happy to be here
pics please?
11-07-2007, 07:06 PM | #10 |
I took a few pictures so I could show the problem I am having. The only thing I can think of is that maybe the uppers are on the wrong side of the truck? Any other ideas?
11-07-2007, 07:41 PM | #11 |
Happy to be here
OK, that's what I thought you meant. You have me stumped there. I have never seen that happen. I have the same spindle on my 77 and have no clearance issues.
Have you considered calling DJM?
11-07-2007, 07:57 PM | #12 |
I thought about calling DJM, I will give that a shot as a last resort. If I hit the spindle and the control with the grinder it will fit, it looks like the casting of the spindle has a little too much on it where there is a ridge is on the top.
11-07-2007, 08:08 PM | #13 |
Happy to be here
I think I would clean up the edge of the control arm rather than the spindle. It doesn't look like it would take much to clearence the lip.
11-07-2007, 09:39 PM | #14 |
Here is what mine look like.
Looking at the 'keyhole' slot and the upper bump stop, it does look like you have the upper control arms swapped.
- Greg |
11-07-2007, 09:56 PM | #15 |
Flat Black, & Chrome!
Yeah you have the upper ca's on the wrong sides
11-07-2007, 10:27 PM | #16 |
The small slot in the upper control arm should face the front . It is the slot that the brake hose bracket mounts to . You can see it clearly in 454HO's post . Frank
Born and proudly residing in a Red State ! |
11-09-2007, 06:22 PM | #17 |
Yea I do have the uppers on the wrong side. I figured there had to be a reason for that clearance issue. Thanks for the help
11-09-2007, 10:33 PM | #18 |
Happy to be here
Flip them around and report back. I have to know for sure...
