2 Questions
I just finished installing new coil springs and shocks on my 72. I have a little bit of play in the steering, any idea what I could change to tighten it up?
I also just finished putting new weather stripping on both windows. The only thing I haven't replaced is the trim at the base of the window. To do this, I think I need to remove the panel, but I can't figure out how to remove the door handle. I see a clip on the inner portion of the window handle, I'm assuming it'll come right off when I remove the clip? If so, is the door handle the same? On a side note, thanks to the members posting pics here, the front coil spring replacement was VERY easy. Took about 2 hours but now that I've done it, I could easily do both sides in an hour. If anyone has any questions about changing theirs out, feel free to ask. |
Re: 2 Questions
Was the steering sloppy before the springs, if not check everything to be sure you got it all tight. Slop in steering is usually tie rods or ball joints. As for the clips, there is a tool for them can be bought at autozone or the like for $10-15. good luck lets see picts!!
Restoration Desperation
Re: 2 Questions
I assume by "play" you mean slack over 1/4 inch when truning the steering wheel back & forth? Haven't had to do it on a my Chevs, but this was how i did my CJ. There should be a bolt/nut combo ontop of the steering box. Loosen them up and then turn the bolt clockwise screwing it into the box. I would jack the front end up and have someone work the steering back & forth while you adjust the bolt. Once its where you want it, tighten the nut underneath the bolt. Just don't over do it. If it won't take the slack out, you will need a new steering box or a rebuild.
You mean they make a spring clip remover...?? I always just use a small curved screwdriver...lol! RD |
Re: 2 Questions
Ditto on what Motor7 said. Just tightened the same on my 68, took all the slop out. And this might be ghetto but I normally use a butter knife that I bend to remove the window/door handles. Just slip it down in there till you can catch the clip and push it out. Note, close the door so the clip stays inside and not somewhere in the yard. (My wife is all the time complaining about "where are all my butter knives going to"), I dont know.............
1968 chevy shortbed, Dark Shadow Gray 4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom |
Re: 2 Questions
Good info guys. Yep, it's the looseness when turning it left or right. It was happening before I upgraded everything. I'll see if I can adjust it out. Thanks.
Re: 2 Questions
my standard answer for changing springs is change the balljoints and tierod ends to avoid doing the job and wheel alignment twice
Old Skool Club
![]() Join Date: Jun 2001
Re: 2 Questions
The clips that hold the handles on are easily removed with the cheap sheet metal tool that most parts houses sell. I have also heard that you can take a shop towel (for instance) and use it to pop the clips off. The fun part is is figuring which side of the handles they're on to remove them.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
chrome makes it go FASTER!
Re: 2 Questions
I just use a small screwdriver to push out the clips. I have metal door panels, so I stick a magnet to it right below the clip. Most times the clip falls right to the magnet.
She can't cook and she won't clean. But she looks good in a skirt and she brings me beer. She can stay for now. EDIT:: But she left me anyway, So forget her. 1962 GMC Stepside V6 4 speed My rolling resto thread http://67-72chevytrucks.com/vboard/s...d.php?t=324226 My old farm truck http://67-72chevytrucks.com/vboard/s...=1#post3465005 |
Re: 2 Questions
as for the play in the stearing have somone turn the wheel back and forth just enough to take up the slop while you look ounder it to see where the slop is. to remove the door handle clips i just bend the end of a piece of wire to make a little hook to pull them off
common sense isn't so common anymore |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: 2 Questions
Over the years, a great majority of the steering slop I've found has been the idler arm being worn.
Re: 2 Questions
just a note of caution here, be carefull with that adjuster, go easy and make sure it isn't adjusted to far or it will bind, adjust a bit and turn it lock to lock. if its still to loose adjust a little more, if you feel a bind in the steering wheel or some tightness, back off a bit.
bad things happen when the box binds. this is just common sense but it bears saying. good luck !
i survived cancer and kidney stones, but my kids are killing me. |
The Older Generation
Re: 2 Questions
I did the "steering adjustment" on an old Dodge truck I had many years ago. I took it out for a test drive and the first time I turned to the right it wouldn't straighten back out and I went through a wire fence and almost hit a tree.... ![]() Just my 2¢ worth. LockDoc
Re: 2 Questions
I plan on changing the tierod ends and ball joints, but I'm still waiting on the parts to come in. I think I'll change those out before adjusting anything.
laying low
![]() Join Date: Mar 2001
Re: 2 Questions
Good idea...
