11-07-2007, 11:37 AM | #1 |
FS, Complete 350, 350 turbo trans.
I have a good rebuilt 350 with a rebuilt 350 turbo trans. I have had this for a project and was going to put it in my Blazer, but with the way gas prices are supposed to go up I am going to rebuild the 4.3 instead and keep the overdrive.
Alittle info on the motor. I dont know how many miles are on the motor but I pulled the pan and everything is fresh, crosshatching on the cylinders show almost no wear. The guy I bought it from said it has less than 2000 miles since built and should be over 300 hp, runs very strong. The cam has a mild idle, ( dont know manufacturer). The motor is complete, carb to pan. ( Rochester carb, stock HEI distributor, water pump, starter, Taylor plug wires. Motor does not burn any oil, plugs are showing a clean burn and no oil consumption. The block casting #s are 3970014, casting date is L 27 73 ( Sep.27, 1973 ). The block stamping # is T 1031CMR. Heads casting #'s are 3890462. Head date code is L 15 6 ( Dec. 15, 1966 ) These heads are 327 double hump 62 cc chamber heads , (no accesory holes) and were rebuilt when the motor was. I was told they are Corvette heads but without pulling the heads to check for the 2.02 valves I cannot say for sure. If anyone is serious about buying I can pull the heads to know for sure. Transmission is a fresh Turbo 350 with new torque converter. Came out of a Chevy truck. I will sell the motor for $ 600.00 I will sell the trans for $ 300.00 If they sell together $ 800.00 If anyone has any questions feel free to ask. Last edited by outlawc; 11-07-2007 at 11:51 AM. |
11-07-2007, 01:13 PM | #2 |
member
Re: FS, Complete 350, 350 turbo trans.
i checked those heads
in 1966 passenger, camaro, nova, chevelle,327 4bbl Qjet 275 hp in 67 327(Your year) corvette 300,350 HP also 67 302, z28 Hi Perf. Sorry but it doesn't tell the valve sizes
1967 C/K10 Chevy Panel 1968 C/K20 Chevy Pickup 1968 C/K10 Chevy Suburban 1941 Chevy Sedan Delivery 1960 Chevy Sedan Delivery 1972 Camaro SS 396 #s matching 1971 Harley FX Superglide |
11-07-2007, 08:39 PM | #3 |
most of those old heads have 1.94 / 1.5 valves.
"Green Monster" (Red Sox fan) 1970 GMC survivor, 350/200 4R, 3.42 rear gears, 2.5/4 drop, ECE disc brake conversion, powder coated suspension |
