Clutch Rod Hole Plug
I can't find a source for a firewall plug for the clutch rod hole. Does anyone have a suggestion?
Tom
'69 swb stepside in progress. '59 Corvette lifetime project Last edited by basketcase; 11-07-2007 at 01:39 PM. |
Re: Clutch Rod Hole Plug
I plan to just weld mine up and paint it...
All Toys: 1971 C10 Fleetside - I needed it! 1970 C10 Stepside - Midlife Crisis 1969 C20 3/4 Longbed - Beast! 1966 Mustang Fastback - Daily Fun 1965 Mustang Fastback - Money pit! |
That would have been a good way to go but I'm a little past that point already. Also I want to keep my options open for a 5 speed later on.
Tom
'69 swb stepside in progress. '59 Corvette lifetime project Last edited by basketcase; 11-07-2007 at 02:09 PM. |
Thanks for the link to Kenny's. They seem to be having a server problem so I'll try again later of just call them.
Tom
'69 swb stepside in progress. '59 Corvette lifetime project |
![]() Join Date: Mar 2005
i tried to go to his kenny's web site the other day. i figured it would be fixed by now!!!! i know he has some. if you make a wtb post in the parts board someone might have one available. they sale for $5-10. i had one but gave it to shaneschevys for his panel truck project..
www.kennystrucks.com
kenny has re-popped and he might have some originals laying around.. |
The fram fuel filter looks good on the head, but I would worry about it getting hot.
On the fast track to nowhere..
If you subscribe to the board you can post a WTB in the classifieds, I'm sure someone will have one. It's 25.00 you won't regret spending!
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
Who's got steelies?
![]() Join Date: Feb 2006
I've seen the plugs that Kenney's sells. If I recall correctly, they were a metal bolt on affair. Seem like I saw a plastic plug similar to the grommets used in the other firewall openings that snaps in on a '71 GMC at my local salvage yard.
![]() ![]() ![]() ![]() ![]() ![]() How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
Watch out for your cornhole !
![]() Join Date: Jun 2003
The original ones did indeed bolt on. It's a metal plate with rubber gasket on the backside.
That's how I got one...there is a few of the members have them and will sell you one.
Alex 1971 Lil' Red 350 SBC 700R4 |
Official Site Guitar Shredder
Hey basket case what headers are those.....?
I guess I thought it was a plastic push in plug too. Since It's a bolt in I can make one out of some aluminum plate I have laying around. The same stuff I used for the heat shield in the back of my fuel filter in the above photo. Thanks everyone for your help.
The headers are original 1981 Corvette stainless manifolds. I removed the bolt on stamped heat shields and cut off the AIR tubes. Then I welded in the holes and coated them with Eastwood's stailess header coating. Corvettes used similar manifolds up through the 80s and 90s until the LS1 engines came out in '97. Most are 2 1/2" outlet but the '81s are 2". They are cheap to buy used at swap meets and make a cheap stainless header if you don't mind spending some manual labor time on them. Tom
If You Have A Friend With One, You Can Trace And Cut It Out. It Bolts To The Firewall
![]() It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan |
#15 |
its all about the +6 inches
I've been told that 67 - 69 were plastic plugs, and the later ones were the metal plate.
#16 |
I go along with that since there are no screw holes around the big hole.
#17 |
I have a 70 cab that HAD a plastic one. My son seemed to think the only way to get it out was in pieces.
#18 |
Who's got steelies?
That interesting. I've never seen any A/T trucks in yards around here that had the mounting screw holes. Maybe it varied by factory?
![]() ![]() ![]() ![]() ![]() ![]() How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel Last edited by oldgold70c10; 11-17-2007 at 05:51 PM. Reason: add |
#19 |
excuse me... I couldn't remember if he said 67 - 69, or 67 - 70.
#20 |
My 70 doesn't have any bolt holes where the cover should have been installed, so it is my belief that there was a plastic option at one time. I was going to try to take a clutch boot, and "install" some sort of cover inside it to plug my hole without having to bolt anything on. Some of the new cars use large plastic plugs/clips with a washer looking side to them. I thought you could use one of those installed in a clutch boot to seal up the hole.
"Green Monster" (Red Sox fan) 1970 GMC survivor, 350/200 4R, 3.42 rear gears, 2.5/4 drop, ECE disc brake conversion, powder coated suspension |
#21 |
![]() ![]() Join Date: Dec 1999
67-70 had a plastic plug. I have a couple. Not for sale. But my view is that the heat from the manifold warped them and they just fell out. The plug only came in grey.
2008 Chevy HHR 1/2 panel. 1949 Chevy Panel truck(just sittin, waiting) Board member #6 |
#22 |
That is exactly what I had thought they were. I should get around to fabbing something this weekend.
Tom |
#23 |
70 C/10-Work in progress
my 70 has the metal cover, I wonder if they changed mid-year??
In the garage 1999 Dodge Dakota Sport-Daily Driver 1972 Chevy K/5 CST AC/PS/PB/4x4/Tow Hooks/Tilt 1970 Chevy C/10-Current project |
#24 |
Mine is chrome and has 2 screws that hold it
#25 |
![]() Join Date: May 2007
here what one looks like.I pulled it off a blazer today
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
