resident wrencher
prob is that my tach dosnt work it has the wires but arnt pluged in wher do they go
Registered thread killer
Re: tach problems
Depending on your ignition system, one wire would go to ground, and one to either the coil (-), or distributor if the coil is part of the distributor, if your coil is integrated into the dist, they usually have a dedicated tach prong marked (tach) . and if you have a light, one would go to a switch activated wire when you turn your lights on.
!966 stepside, 350 SB, ZZ-4 roller, Crane roller rockers, 0.030 flat tops, airgap intake, 750 Holley, stainless steel headers, edelbrock SDT mufflers, Mark 8 elec fan, 700R-4, column shift Last edited by 04Xrider; 11-07-2007 at 09:35 PM. |
resident wrencher
Re: tach problems
its a stock points and condenser
