11-11-2007, 06:57 PM | #1 |
resident wrencher
haeders
dose any one have headers on their trucks do you have full lenth or shorty block huggers what
11-11-2007, 08:01 PM | #2 |
Re: haeders
I have a set of Hookers on my '65 with a small block.. they are full length with 2.5" collectors rather than the normal 3" collector.
I am fixing to pull my engine for a re-ring and bearing job and will either install some ramhorns or Hedman hedders. I found the only way to get the Hookers to seal were by cutting the head flanges and using Fel-Pro gaskets exclusively. |
11-11-2007, 08:07 PM | #3 |
resident wrencher
Re: haeders
you didnt have to notch the frame to get them in
11-11-2007, 08:22 PM | #4 |
Re: haeders
Not with a small block.. Big Block you have to do some cutting..
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
11-15-2007, 02:25 AM | #5 |
Re: haeders
No, the headers do not have a clearance issue with the frame, motor mounts or crossmember but I did have to dimple one tube to clear the stock clutch linkage (bell crank specificially). The worst part is that the routing of plug wires is tricky and the adjuster for the clutch snakes though the header.
11-11-2007, 08:41 PM | #6 |
Re: haeders
I run a set of Hooker 2452 headers. Had to do some clearancing for clutch and at least one plug...what else is new. They haven't leaked even once in 5+ years, best headers I've ever had.
64 Panel Rebuild Pics Clutch Replacement and Borg Warner T10 Trans Rebuild 64 Panel 1/2 Ton 350cubes/400hp BorgWarner t-10 3:73 Auburn Posi |
11-14-2007, 10:45 PM | #7 |
Re: haeders
What was involved in the clearanceing and the plug? I have rams-horns and an auto, but I want to switch to a manual and headers. According to the headers I have seen, they don't fit manual trans 60-66 chevies.
11-15-2007, 02:28 AM | #8 | |
Re: haeders
YMMV |
11-15-2007, 10:02 PM | #9 |
Re: haeders
I have blockhuggers now but am looking at getting the mid length.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
11-11-2007, 09:47 PM | #10 |
Why does it taste purple?
Re: haeders
I have a set of Dynomax Headers that are just sitting up in my attic.Im not sure if they are goin to clear the clutch bar on the frame.If they don't,what can I do to make them fit?
11-11-2007, 11:37 PM | #11 |
Re: haeders
i got shorty block huggers
ridin big yo 5in cpp lowerin springs in back lowered 3in in front with cut springs for now 5 lug swap and disk in front 5 lug and disk in the rear with 3.23 gears mild 350/400heads 7547weiand intake 600 Edelbrock chrome block hugger headers 2 1/2 pipes in to a x pipes super 40 flows and turn downs turbo 350 with shift kit |
11-12-2007, 12:14 AM | #12 |
Re: haeders
I did, but they habg below the frame, they were a set of hedmann's. I'm going to lay frame, so it's a no go for me.
11-14-2007, 06:43 AM | #13 |
Re: haeders
I use shorty block headers.
This one time at bandcamp, in my c10, I ran over the girl hiding the flute! http://67-72chevytrucks.com/vboard/s...d.php?t=255141 |
11-14-2007, 08:12 AM | #14 |
Registered thread killer
Re: haeders
Another shorty block huggers here, no issues I went with a set of stainless steel.
!966 stepside, 350 SB, ZZ-4 roller, Crane roller rockers, 0.030 flat tops, airgap intake, 750 Holley, stainless steel headers, edelbrock SDT mufflers, Mark 8 elec fan, 700R-4, column shift |
11-14-2007, 08:26 AM | #15 |
KEEP ON TRUCKIN'
Re: haeders
Didn't have to do any cutting on the full length bigblock headers in my K10. I don't remember the name of the headers but call http://www.summitracing.com and tell them what you have and they will head you in the right direction.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" |
11-14-2007, 09:16 AM | #16 |
Hollister, CA.
Re: haeders
I too am running the short block hugger...I tucked my exhaust above the bottom the frame......planning ahead for bags.
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
11-14-2007, 12:04 PM | #17 |
resident wrencher
Re: haeders
real nice cheif and thanks to every body hey cheif whats up with your water inlet thing (the words escaped me)
11-14-2007, 12:16 PM | #18 | |
Re: haeders
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 Last edited by Chevy Fleetside; 11-14-2007 at 12:21 PM. |
11-14-2007, 12:57 PM | #19 |
Old Time Rodder
Re: haeders
Am running Sanderson block huggers and had to cut the side off the driver side motor mount. Just a small amount for clearance, didn't have to remove, just used a torch. When I replaced the engine just dressed it up a little before reinstalling. I had Hedman regulars and didn't like them dragging all the time, since I have a 4/6 lowered truck.
79 GMC SWB Lowrider Stepside [81 cab] that thinks it a Chevy (since 6/1980) Replacement cab had A/C which now works, made a real truck out of it 84 MC 305 350TH 3.08 4 wheel disc finally My daily driver again |
11-14-2007, 01:34 PM | #20 |
Re: haeders
Sanderson Headers 3/4 length. This particular header was designed to fit lowered 67 - 72 trucks and therefore no mods are necessary. For gaskets I use Permatex Ultra Copper.
esll.
Tomorrow is for doing today's stuff. ************************************* This truck has just the right amount of energy for me! Author: Warren Lake .... (member) Last edited by EAST SIDE LOW LIFE; 11-14-2007 at 01:35 PM. |
11-14-2007, 01:54 PM | #21 | |
Re: haeders
I couldn't really tell, are you running a manual transmission? Do they clear the clutch rod linkage? |
11-14-2007, 12:04 PM | #22 |
resident wrencher
Re: haeders
i mean its backwards
11-14-2007, 05:27 PM | #23 |
resident wrencher
Re: haeders
hey east side low life whats the # for the place you got your sander sons and how much were they
11-14-2007, 06:29 PM | #24 | |
Re: haeders
Hi there Kris, The Sanderson headers [ECE's part #11 - 6572] were $379.00 bucks. Let me say though they are quality from the get go. I have two phone #s .... 1.) Order line - 888 - 777 - 0395 2.) Tech line - 559 - 299 - 1611 I hope this helps. These #s will get you in touch with ECE who is a dealer for Sanderson and their price is better then going direct to Sanderson. esll.
Tomorrow is for doing today's stuff. ************************************* This truck has just the right amount of energy for me! Author: Warren Lake .... (member) |
11-14-2007, 07:08 PM | #25 |
resident wrencher
Re: haeders
thanks esll
