Old 11-14-2007, 12:15 AM   #1
speedypalomino
speedypalomino's Avatar
whats that noise!?!?
so,,, I encountered a TERRIBLE and VIOLENT noise while on the way home today!!! my question,, who produces the highest quality ring and pinions???? and should I be concerned about my np205 after this destruction???
guess I get to buy that Aubur Ected locker I've been droolin over!!
Bear :O)
( pinion chunks in pic)
Bear.
speedypalomino is offline   Reply With Quote
Old 11-14-2007, 12:38 AM   #2
krue
Designated A-hole!
krue's Avatar
Re: whats that noise!?!?
That truly sucks!
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 11-14-2007, 11:50 AM   #3
crzngmychvy
"1972 C5"
crzngmychvy's Avatar
- 72 2wd Blazer ...sold...
2wd Blazer Page
crzngmychvy is offline   Reply With Quote
Old 11-14-2007, 01:09 PM   #4
speedypalomino
I was just cruisin home, bout 30mph and slowing to make a courner when the first in a series of loud, truck shaking BANGS came from,,,, back there.... made it the last 3 miles home, startling Horses and Cows the whole way,,, not much oil left by the time I got home due to the holes in the dif cover,, but it did look rather dry around the pinion bearing,,,
took the back plate off the transfer,,, looks great in there, no pieces, oil was really clean....
Bear
and a happy Veterans day to all my fellow Veteran brothers and sisters.....
Semper Fi (USMC 85-91)
Bear.
Old 11-14-2007, 01:56 PM   #5
ABLAZN
Oh..never mind....
ABLAZN's Avatar
As far as gears go, Richmond Gear is very good. Also, a lot of the local 4X4 guys are using Yukon gears and seem very happy with them too. The Yukon's are are a little less money to boot. I hope that help, and sorry to hear about the rear end grenade.
1972 Blazer
-6 inch lift
-35 inch BFG A/T's
Turbo 350
NP-205
454 BB (for now)
MORE TO COME !!!!!! Now going to 2WD!!!!!
Sold.
I got it back after 22 years and did not even know it !!!
THE STORY HERE
Project Low Down Dirty Rat
ABLAZN is offline   Reply With Quote
Old 11-14-2007, 03:15 PM   #6
speedypalomino
yeah,, the tires are 35's, and the gears were 3.73's, but were a used set the PO had a buddy put in ,, so who knows if he knew what he was doing,,, when I owned this Blazer previously (early 90's) the carrier broke in the original rearend,,, so I'm thinkin the old Blazer is cursed!!! :O)... I've never beat on this rig, and the only wheelin it sees is on the farm, so I can't really justify a 3/4 ton swap... I don't mind spendin the extra $$$ on a better quality gear set..
thanks for the input!!! :O)
Bear
Bear.
Old 11-14-2007, 11:30 AM   #7
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
How did you grenade the pinion? What was happening at the time?
Ya might drain your transfer case and check for any issues in the fluid (fragments, etc) but NP205's are quite strong.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 11-14-2007, 01:53 PM   #8
bouncytruck
SKINNY TIRES RULE!
Well, it might be a good time to look at your gear ratio and consider re-gearing if needed. If that's your truck in the avatar, it looks like you're running about 33's. You probably want a 3.73 or so ratio for those tires. Randy's Ring & Pinion in Everett should have what you need and it's not too far away from you.
bouncytruck 1972 K5
Old 11-14-2007, 04:09 PM   #9
bouncytruck
SKINNY TIRES RULE!
If you run a different ratio, you'll need to do the front too. My last rig had 35's and 4.10's. It was much better geared than my first one which had 35's and 3.73's. You might find it cheaper to put a used 3/4 ton set under the truck than new gears - but ya might end up in the same situation your in now a few years down the road.
I don't know what is up in your area, but http://www.oly4x4.com/ is in Snohomish and http://www.4wheelparts.com/ is in Lynnwood. I'd guess there was a 4wd shop someplace up around Bellingham or Mt. Vernon.
bouncytruck 1972 K5
Old 11-14-2007, 05:05 PM   #10
speedypalomino
yup,, it was called Northwest Offroad,,, John Hendricks ownes it, he closed the retail store and only does online sales now,, (he's a bit of a strange duck... lives just down the road) the sad thing about goin 3/4 ton,,, I just bought those new wheels to better fit my new tires!!
when it rains, it pours!!!
oh... and with the 35's and 3.73's.. my speedo is right on...
so I don't want to change that and create a new headache....
well I guess its road trip time!!
Bear.
Bear.
Old 11-15-2007, 09:50 AM   #11
Burt4x4
Burt4x4's Avatar
Bear :O)
ooops
My .02c do NOT buy Genuine Gear. I would get Spicer, Youkon or Precision Gear R&P and make sure your master install kit comes with Timkin bearings and Natonal Seals.
Oh and I doubt that hurt your 205 in anyway
Good Luck
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
