Old 11-14-2007, 04:58 PM   #1
cstm68
cstm68's Avatar
trans to bell housing ???
ok i when to bolt my 4 speed up to me bellhousing and the hole in is too big by about 1/4 " (see first pic)
is this gap a problem or can i just bolt it up and not worry about it?? everything eles fits great
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308
2014 Chevy 2500hd duramax CCLB
cstm68 is offline   Reply With Quote
Old 11-14-2007, 05:06 PM   #2
cstm68
cstm68's Avatar
Re: trans to bell housing ???
also is this a ratio?
1st 3.50
2nd 2.48
3rd 1.65
4th 1.00
Old 11-14-2007, 05:08 PM   #3
cruiserman
Not a problem IMO.
72 C2500 LWB 402 Sierra Grande
05 Odyssey
08 Tundra
cruiserman is offline   Reply With Quote
Old 11-14-2007, 05:09 PM   #4
Garage Freak
Looks great to me.
Garage Freak is offline   Reply With Quote
Old 11-14-2007, 05:21 PM   #5
cstm68
cstm68's Avatar
i was told that i hekps the align the trans, but if it goes into the clutch fine and the bolts line up than it should be fine right?
Old 11-14-2007, 06:35 PM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Some guys who I really respect have told me that a thin spacer ring is order of the day there. It's critical that the crank and mainshaft centerlines are identical.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 11-14-2007, 07:18 PM   #7
cstm68
cstm68's Avatar
where can i get this spacer ring?
Old 11-14-2007, 07:58 PM   #8
Tx Firefighter
The main guy I remember is a HAMB'r named Squirrel. I believe he wound up making his own.
Old 11-14-2007, 08:09 PM   #9
cstm68
cstm68's Avatar
would you happen to know how he made it?
Old 11-14-2007, 08:19 PM   #10
Tx Firefighter
Knowing that maniac, I'm sure he made one out of billet steel on a lathe and mill. He's way beyond me when it comes to this stuff.
Old 11-14-2007, 08:34 PM   #11
crazy longhorn
Fabricate till you "puke"
You can also use the input bearing retainer from a saginaw 3spd(68-up truck), or opt for a 67 or older truck bell to run the car trans....L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 11-14-2007, 09:45 PM   #12
cstm68
cstm68's Avatar
ok so i dont know i thing about trannys so what is the input bearing retainer?
i do have 2 saginaw 3 speeds to take one off (if i new what one was)
Old 11-14-2007, 09:53 PM   #13
Tx Firefighter
It's that big cast iron front piece that fits into the bellhousing bore.
Old 11-14-2007, 11:33 PM   #14
cstm68
cstm68's Avatar
so if i pull thoes 4 bolts out will it just slide off over the shaft?
will it take anything out with it or will anything try to fall out?
by the way thanx for all the help guys
Old 11-15-2007, 12:43 AM   #15
Livrat
Member #1049
Livrat's Avatar
Yes, Just remove the bolts and it will slide off.. nothing will fall out.
Livrat is offline   Reply With Quote
Old 11-15-2007, 01:13 AM   #16
cstm68
cstm68's Avatar
thanx for all the help.
Old 11-15-2007, 08:47 AM   #17
prg machine
prg machine's Avatar
just go get the right bell housing. I wouldn't run that tranny with all of that clearance in the bell. Bell housings are cheap.
prg machine is offline   Reply With Quote
Old 11-15-2007, 09:31 AM   #18
crazy longhorn
There is a gasket to replace, & a seal inside the collar. You will be wise to go ahead & replace the front bearing on the input shaft while you are in there. i have seen that front bearing let go & scatter the trans. When you pull the collar, you will see a snap ring on the input shaft.....remove that & carfully wiggle the bearing off. The shaft should stay with the trans, but will try to move foward. I would hold pressure rearward on the shaft to keep the shaft in place,& 4th gear syncro in its keys. Button it up & you are good to go. The truck bell(68 -up) has a 5 1/8" center hole, vs the 4 11/16" hole for the car , or the 67 & older truck. L
