Old 11-14-2007, 08:25 PM   #1
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Factory gear ratio options for Dana axle on 3/4 ton
I popped the cover on my Dana rear axle today to service the innards and clean it up a bit.
It's a 3:54 ratio. Is this a stock ratio option or do I have a later rearend in my junk?
Kevin
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 11-14-2007, 08:37 PM   #2
67_C-30
I have a radical idea!
67_C-30's Avatar
Re: Factory gear ratio options for Dana axle on 3/4 ton
That's a stock ratio. It's actually a great all around gear for a 3/4 ton unless you're gonna be doing some real heavy towing.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 11-14-2007, 08:40 PM   #3
Tx Firefighter
Thanks for the quick response. I actually could not be any happier with the ratio. I tend to do a good bit of highway driving.
Old 11-14-2007, 08:42 PM   #4
67_C-30
67_C-30's Avatar
I agree. I am going to probably drop the gear ratio down to a 3.42 in my 67 C-30. That is the closest thing you can get in the 14 bolt I put in there. You put a 265/75R16 or a 285/70R16 on the 3/4 ton, and it will roll out with 3.54's!
My trucks
Old 11-14-2007, 09:32 PM   #5
Tx Firefighter
Yep, I roll on 265/75/16's and my truck cruises.
Old 11-14-2007, 10:13 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
that was only avalible in big block trucks.
Old 11-14-2007, 10:16 PM   #7
67_C-30
67_C-30's Avatar
Ahhh.. I didn't know that. Good to know though. What was common behind the 351E V6's?
My trucks
Old 11-14-2007, 10:56 PM   #8
1969 GMC
1969 GMC's Avatar
I'm sure if you really wanted it, you could have ordered it w/o the BB.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 11-14-2007, 11:15 PM   #9
Rod
Had 3.54 in my 70 3/4 GMC 350/400 coils rear and in a 71 Chev 3/4 350 coils rear. Not just BB. Was the factory ratio if you had a 3/4 BB anything else was an option. Mind you were talking dana diffs here and not eatons.
Rod is offline   Reply With Quote
Old 11-15-2007, 07:55 AM   #10
My`72 K2500 has 3.54s and it loves the hiway for a heavy 4wd.I have 12.50/33s and it catches second if I`m on it (with power-loc).It hauls great,too.That ratio works with o/d just as well.From all I`ve gathered,the highest gearing with o/d that leave grunt enough to tow/haul is 3.42.That`s what goes into my`67 shortbed w/M22.It`ll roll pretty good like that.I think 3.08 would be too high for a manual.With any luck,it`ll end up with a GearVendors unit.
Old 11-15-2007, 11:18 AM   #11
Tx Firefighter
K, I agree with you on gear ratios.
At heart, I'm an 88-98 Chevy truck guy. I worked on a million of them in the mid 90's as a dealership mechanic. A huge majority of them had 3.42 and overdrive. It's a perfect combination in my opinion.
As a side note, GM produced millions of 305 powered trucks in the early to mid 80's with the 700R4 overdrive and 2.73 rear gears. Talk about sick. I've converted a lot of them over the years to straight turbo 350's from the 700 and the 2.73 is still too tall even without OD.
Old 11-15-2007, 11:39 PM   #12
I worked for a company that ordered three`81 trucks,all red/almond two-tone.Two were 1/2t and a 3/4t.The 1/2t trucks had the 2.73s/305/4spd manual drivetrain.I used granny to start off.I couldn`t imagine those staying in o/d on any grade at all.The masonry crew had the 3/4t at first,until we disolved that crew and started subcontracting.Then,I got that truck...350/3.73/4spd manual.I liked that one.
Old 11-16-2007, 03:08 PM   #13
tkeduk8r
tkeduk8r's Avatar
I agree... that 3.54 (46:13) in my Dana is great... I just discovered that in my 72 c20... seems like a great all around ratio... now if I could just get my factory tach to read correctly I'd be set...
--Mike
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
