11-17-2007, 10:20 PM | #1 |
72 gmc, power booster? lowering? what can i use?
i am new to this site,,, and i have alot of questions... i am trying to learn exactly how to use this site??? regardless i recently bought a 72 gmc long bed, and i would like to upgrade the brakes a bit... it has the front discs, and i am fine with the drum rears... but i would like to add a power booster.. the question is.. can i use a different year besides 67-72 gm power booster? if not... does anyone out there have one? or any info to upgrade the brakes??
i would also like to drop the truck a bit, perhaps 3 in front and 4 in back... or 4 and 4? or something along those lines... it has those helper springs in the rear,, so i figure i will still keep some payload if i just block the back? do i have to buy drop spindels for the front? or how much should i cut off factory springs? should i buy new shorter springs? i am on a budget,,, but need to keep the truck drivable. it is my work truck... anyway.. i have a lot of questions,,, any help or info would be greatly appreciated... thank you. |
11-18-2007, 08:54 AM | #2 |
Designated A-hole!
Re: 72 gmc, power booster? lowering? what can i use?
I'm gonna move this to the message board for you.
Welcome to the board from South Mississippi!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
11-18-2007, 11:11 AM | #3 |
Licensed to Thrill!
First off - welcome to the board from Northwest GA.
Second thing, if it's your work truck - you don't want to get too low. You'll kill your "towability". A 2/4 would be about your best option I would say. Early Classic Enterprises carries the stuff you'd need to do this, as do others. For the booster - you can use several others beside the factory setup, you just have to make it fit up right. I used a 7" booster setup that was actually for Tri-5 Chevy's. There are a lot of options there - just depends on budget. Check out www.gmcpauls.com. He can hook you up with what you need, and at a good price. DLB |
