11-18-2007, 09:19 PM | #1 |
oil pan on lowered trucks
Do trucks that lay frame need a low-profile oil pan? Never measured before I tore mine apart.
11-18-2007, 11:05 PM | #2 |
Formerly ADHDCARGUY
Re: oil pan on lowered trucks
My oil pan is just a little higher than the xmember on my '67, so the xmember kinda protects it!
Jay 67CHEVY SWB,355, built 700r, 5/7,9",posi 3.50,REAR BAGS,HOOSIERS, A/C. 54CHEVY - BURB, beginning construction(well, i gotta take it apart first!) 36FORD PU - WAITING 38CHEVY - 2DR SD,CHASSIS FINISHED 46CHEVY - BURB - waiting |
11-18-2007, 11:11 PM | #3 |
im rasin my engine ...will help with clearance and drive line angles too
11-19-2007, 06:53 PM | #4 |
I know with PorterBuilts DropMember it raises the engine 2" or so but I think this is for clearance of the rack & pinion. My 71 was laying crossmember with a 92 LT1 and I had no problems.
Kevin LFD Inc. |
11-19-2007, 07:00 PM | #5 |
It'd be alot cooler if you did
stock one works fine with the engine in the stock location and a raised crossmember.
11-19-2007, 09:31 PM | #6 |
11-20-2007, 12:07 AM | #7 |
just like on your truck- the front crossmember. I raised it 1 1/2 inches.
11-20-2007, 09:57 AM | #8 |
11-19-2007, 10:13 PM | #9 |
Seņor Member
Not on the inlines. The stock 250 pan is about 1/2" lower than the bottom of the xmember
