If lowered 2.5 how wide a wheel.......
On a C10 LB if lowered 2.5 in the front how wide a wheel can I run with out rubbing the inner fender?
Re: If lowered 2.5 how wide a wheel.......
I know you can go 8" with no issues. I would guess 10" would probably work depending on the back spacing. You would probably run into interference with the lower control arm before the inner fenders became an issue.
I understand the back spacing on the 10" wheels is the same as on the 8" so the rub would most likely occur on the front side of the tire.
#4 | |
Yes it will, I'm running 2.5" WC spindles and had 10" front rims with a 275/60/15 and the fender lip ate the tire up. I had to go to a 15x8" with a 255/60 to cure it, I think the 275 would work on a 8" rim, but I dont like the way they look on there so I went with the 255.
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded ![]() '03 burb. Family cruiser http://upstategmtrucks.com/ |
#5 | |
Insert Witty Text Here
I'm running 8" rally wheels with 255/70/15 tires and 2.5" spindles. No rubbing.
Slonaker |
Cruzzzn' Vet
I'm running a 275/50/R15 tire on a 15x9 rim on the front of mine with no problems with a 4" BS, front has a 4" drop
I plan to go with 10s on the back eventually, but my tires are almost new. I probably won't be doing it for a while. Its not like I have any traction problems with a stock 350.
![]() Slonaker |
