11-21-2007, 08:47 PM | #1 |
20 inch wheels with 5/7 drop
I would like to run 20x8.5 up front and 20x10 in the rear. I have an 84 c-10 . I ike the big lip look in the rear and need to know what backspace I will need front and rear so they dont rub.Any help on tire size also. Thanks for the help in advance
11-21-2007, 09:33 PM | #2 |
Re: 20 inch wheels with 5/7 drop
im running that wheel combo on my 86
5.5" bs on back, and 5.25 up front. 245/40 front 295/45/20 rear no issues at all, could probably go with a little bigger tire up front.
1986 C10 SWB 6.0/6l90e Miami...Flee it like a native |
11-21-2007, 09:37 PM | #3 |
Low & Fast!
I have been looking for about year on what I was going to get. And I have just ordered them.
Here is what you need. front 8.5 wheel BS 5" with 245-40-20 or 255-40-20 Back 10 wheel BS 4.5 with 295-40-20 this will give you a little dish. Trav
11-21-2007, 10:32 PM | #4 |
Thanks guys for the info. PCM COBRA could you tell me if you were to lower your truck more would your wheels and tires tuck with out rubbing. I am 5/6 now and may lower the rear one or two more inches Thanks again for the help I just want to make sure I know what I need before I buy.
11-21-2007, 10:35 PM | #5 |
Hey TVBlazer78. Do you have a pic of your wheels so I can see the offset you have. will your wheels tuck without rubbing. Thanks
11-23-2007, 05:29 PM | #6 | |
Should be 5.5 on a 10" wheel.
86 SWB 9.0 LITER T-400-OD 4.11 eaton-4/5 drop Best 1/4 12.51 @112mph no traction |
11-23-2007, 05:34 PM | #7 |
rear wheel is 9.5 with 5" BS
11-23-2007, 08:06 PM | #8 |
Low & Fast!
Sorry that you do, but I have a 9.5 with 3.5 BS on it. It's a stock 12 bolt out of a 4x4 blazer. Here is the pic.
11-21-2007, 11:39 PM | #9 |
ya, mine would tuck.
11-22-2007, 08:39 PM | #10 |
Thanks again for the info. I will call and order my wheels this week.
11-23-2007, 12:33 AM | #11 |
Low & Fast!
here is one of my old 17x 9.5 BS 3.5, had to roll the lip of the fender up to make them fit..
11-23-2007, 09:01 PM | #12 |
OL BLUU
I have 20x10's w 5.25 BS... I was going to go 5.00 but I run the disc covers and a 1/4 spacer as well. (I use the 1/4 spacer to keep my dust covers off of the drum weights; so they dont get dented)
11-24-2007, 10:34 PM | #13 |
Thanks again for all the info. The 5 to 5/14 inch backspace looks like the way I need to go if I want a 20x10 to tuck without rubbing. If anyone has any good pics of 20 I would like to see them.
11-25-2007, 06:24 AM | #14 |
good move getting at least 5" backspace. Here's a pic before I installed a 4 link.
11-25-2007, 08:46 PM | #15 |
Very nice truck Airmail. Thanks for the picture.
11-25-2007, 08:49 PM | #16 |
Hello Airmale could you tell me what size tire you are running
11-25-2007, 11:40 PM | #17 |
Rear 20x10's w/the equivalent of 5" BS was dead-on for my daily 5/7 static-dropped driver..... As you can see in the pic, the rear tires are slightly tucked @ ride height.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 11-25-2007 at 11:41 PM. |
11-28-2007, 10:55 PM | #18 |
The Crazy Machanic
heres some 20s for you its on my moms truck. she didnt lower casue she loves using her truck, that and it a 4 wheel drive, but still a very nice truck
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day) * 1970 chevelle 2dr sedan Latest update June 24 2007. *1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad) newest additions 1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in and a 79 c60 trash truck um no idea i have one |
