11-21-2007, 11:41 PM | #1 |
Gas smell in cab interior
About twice a week I get a strong gas smell inside the cab. Sometimes it stays there for hours and sometimes for 15-20 minute before going away. I have a '71 pickup with the original gas tank which is in the stock location. I believe that all of the hoses are connected correctly and am using a new cap. Any suggestions as to stopping the gas smell? I would rather not relocate the tank.
11-22-2007, 12:03 AM | #2 | |
Maintenance Man
Re: Gas smell in cab interior
No, seriously. I've been riding in/driving these trucks for 30 years on and off. There was ALWAYS a slight smell of gas in every single one. I've owned/operated/been a passenger in at least 8 of these trucks (long term, not counting the occasional ride in other peoples trucks over the years) and it has ALWAYS been an issue. |
11-22-2007, 12:20 AM | #3 |
This is not a slight smell - it smells like someone poured gas on the floor.
11-22-2007, 12:29 AM | #4 |
Old member
Check the vent tube on passenger side that goes up into the top of the cab.
I have had my truck 20 some years and it would smell bad after filling up. Check the gas neck on the outside to see if it's locking the cap down good. I had to tweak mine some to stop it even with a new cap. Check the tank good for a small leak in the bottom of it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
11-22-2007, 12:36 AM | #5 | |
Maintenance Man
Hmmm, check the vent tubes maybe? If you can, pull the seat out and check ALL the various tubes coming out of the tank. There should be a tube coming out of the top of the passenger side going up into the roof area. Other than that, I have no idea. There will always be a slight smell of gas, but then again my idea of a slight smell might be different than yours. As I've said before, I got brought home from the hospital when I was born strapped to the top of the center console in the '68 CST (the truck had '69 buckets and console). If this is your first experience actually owning one of these old guys, well, that may be part of the problem. Part of the attraction (and admittedly lately to certain members of the female persuasion) is the slight smell of well used old Chevy truck. Mix various parts of Gasoline, Oil, Dirt, Grease, Brake fluid, ATF, Steel, Rust and sweat and the girlfriends eyes kinda get crossed over when I get home from the shop after working on the truck. Never knew why she was into the old cars as she seemed kind of the "pink" girl type. Now I think I know. Question, why do you not want to relocate the tank? |
11-22-2007, 12:47 AM | #6 |
1. Cost
2. Most of the tanks I have seen are too low in back 3. Filler placement options are limited 4. No place for spare tire 5. Does not give extra room in cab 6. Cost But it would get rid of the smell!! |
11-22-2007, 01:25 AM | #7 | ||||||
Maintenance Man
$199 for a brand new kit from Brothers, LMC, and Golden State pickup parts with everything needed but the fuel line going to the back of the truck. I'm sure if you ask around here (on the board) one of the site vendors could get you just as good a deal, if not a heck of a lot better.
11-22-2007, 02:30 AM | #8 |
As for the smell, check the gasket for the sending unit on top of the tank and also the rubber donut for the fill neck/tank junction.
rwgregory 67 GMC 2500 ,2w/d wide box 305 V-6, 4-speed |
11-22-2007, 12:06 PM | #9 |
upgrading to an older model
happens twice a week...hangs around for 15-20 minutes.
Let me guess you fill up somewhere around twice a week, dirve your truck at least 10-20 miles directly there-after. Sounds like when the tank is full you have some sloshing and leaking...I agree with the checking around the filler neck and vent
68 stepside, short-box, multi-colored (for now) |
11-22-2007, 12:15 PM | #10 | |
I agree with rw. Also check the rubber gasket on the sending unit itself as it can become hard and allow gas to bypass it when you fill up. If this is happening you will more then likely see traces of gas on the outside of the tank. If this is the case replace the rubber gasket. This has been the culprit on both my trucks when I could smell gas in the cab. esll.
Tomorrow is for doing today's stuff. ************************************* This truck has just the right amount of energy for me! Author: Warren Lake .... (member) Last edited by EAST SIDE LOW LIFE; 11-22-2007 at 12:17 PM. |
11-22-2007, 12:33 PM | #11 |
Biggest culprit for smell. Does the strong smell coincide with filling the tank?
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
11-23-2007, 12:47 AM | #12 |
The smell does not correspond with filling the tank. I have a new sending unit and a new gasket. I will have to look for a "donut" between the tank and fill neck tube - didn't know there was one there. Thanks for the suggestions!
11-23-2007, 06:14 AM | #13 |
chrome makes it go FASTER!
Did you have chili for lunch?
She can't cook and she won't clean. But she looks good in a skirt and she brings me beer. She can stay for now. EDIT:: But she left me anyway, So forget her. 1962 GMC Stepside V6 4 speed My rolling resto thread http://67-72chevytrucks.com/vboard/s...d.php?t=324226 My old farm truck http://67-72chevytrucks.com/vboard/s...=1#post3465005 |
