Old 11-23-2007, 12:57 PM   #1
lks dcvn
lks dcvn's Avatar
Will Chevy Caprice Rims (5x5) Fit?
I have some winter wheels for my 95 Impala SS sitting in the back of my garage and a 69 truck rolling chassis with crappy rims/tire on it and...
My question is will the 9C1 (cop car rims) fit on my truck chassis - both are 5x5 but didn't know if the rim would clear the hub...or if there was a difference in backspacing between car and truck ralleys...
Here is what they look like...(borrowed a pic from elsewhere)
lks dcvn is offline   Reply With Quote
Old 11-23-2007, 01:59 PM   #2
71 super
71 super's Avatar
Re: Will Chevy Caprice Rims (5x5) Fit?
If they are like the aluminum SS ris they will fit. Friend of mine for giggles put a set of the aluminum SS wheels on 71 2wd and had 0 problems. If there had been he would not have done it- all about the easy.
71 super is offline   Reply With Quote
Old 11-23-2007, 02:27 PM   #3
65 on 24's
65 on 24's's Avatar
yes they will fit i got a caprice rear end in my 65 . they have chevy truck lug pattern
ridin big yo
5in cpp lowerin springs in back
lowered 3in in front with cut springs for now
5 lug swap and disk in front
5 lug and disk in the rear with 3.23 gears
mild 350/400heads
7547weiand intake
600 Edelbrock
chrome block hugger headers
2 1/2 pipes in to a x pipes
super 40 flows and turn downs
turbo 350 with shift kit
65 on 24's is offline   Reply With Quote
Old 11-23-2007, 02:35 PM   #4
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
yes, they will work just fine. You must have done a 6 to 5 lug conversion?
LOW DOUGH is offline   Reply With Quote
Old 11-23-2007, 02:37 PM   #5
jorgensensc
jorgensensc's Avatar
I've got a set on the front of my truck right now.
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 11-23-2007, 02:52 PM   #6
lks dcvn
lks dcvn's Avatar
Nope - but PO did...
And also swapped to a front disc setup as well. This will be my builder frame once I get my solid project to work on...
Thanks Everybody - now I got something to do tomorrow after I eat.
