Old 11-30-2007, 04:52 PM   #1
knightlife
Dark Heart Motorsports
knightlife's Avatar
finally got stumped...
okey dokey... as you all know I usually try and help out when your trucks break down and give advice on what could be wrong... well, turns out, the table is turned lol...
here goes, went to start my truck today prior to PT (wound up having to run there and was late). everytime I turn the key to the on position, everything turns on like normal. When I go to turn the motor over tho, kills all electrical power.
1.)heres what I've found, battery ground is proper from the block.
2.)all wires running to the starter are in good condition, none frayed, none burnt
3.)starter clicks as tho its about to start the motor, right before all electrical power is killed.
any ideas? spose a massive re-wire is due? or am I just over-reacting like always?
thanks in advance for any feedback
Kru
How Deep Can YOU Bleed..?
1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter
2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD!
knightlife is offline   Reply With Quote
Old 11-30-2007, 05:01 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: finally got stumped...
i had a impala cab do that years back and it turned out it was a faulty ignition switch
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 11-30-2007, 06:27 PM   #3
1Ton
1Ton's Avatar
Hows the battery?
Support your local search and rescue team.... GET LOST!
Originally Posted by DURRTY
if some is good
more is better
too much ought to be enough........
1Ton is offline   Reply With Quote
Old 11-30-2007, 06:40 PM   #4
OJOE
Crew Cut
OJOE's Avatar
re check battery connections. if they are good, check ground wire to block and the hot wire at starter. has to be one of these. good luck
85 SWB 1/2 TON CREWCAB/5.3
03 CHEV 3500 DURAMAX CREW CAB
85 CHEV SWB/TPI
06 CHEV TAHOE (WIFES)
30 MODEL A HOT ROD
07 HARLEY DAVIDSON BAGGER
09 STREET GLIDE
AN D A LOT MORE JUNK
OJOE is offline   Reply With Quote
Old 11-30-2007, 07:03 PM   #5
Jonboy
Slots go on anything!
Is the ground strap from the cab to engine still connected?
Jonboy is offline   Reply With Quote
Old 11-30-2007, 07:09 PM   #6
spudz
spudz's Avatar
either bad battery connection, bad ground, dead battery, or bad switch...
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 11-30-2007, 07:11 PM   #7
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Are you sure the wires are good. Corrosion can wick down the copper wire strands and look fine but are not conducting well.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 11-30-2007, 08:51 PM   #8
xtreme80
Wishin' I had more money!
xtreme80's Avatar
My educated guess would be that it's either a bad battery or a bad connection right at the battery. GM uses the stupid side post batteries, and they don't make a great connection anyways, but they do go bad and get corroded.
I would start with the wiring at the battery, or the battery most likely has an internal short.
xtreme80 is offline   Reply With Quote
Old 11-30-2007, 11:34 PM   #9
Duro5341
Duro5341's Avatar
Have the battery load tested........me thinks you have a shorted cell, or there is no reserve to start the motor........that starter probably draws 350 amp on initial start up
Duro
-1986 K10 LWB, 350 HD,TH400
3.08, 30 spline 10 bolt, with an Auburn Posi, 31" tires
All original, second owner truck
-1979 Monte Carlo, 350, 200r4, 3.73 posi
-1987 GT T-top Mustang - slow moving project
Duro5341 is offline   Reply With Quote
Old 12-02-2007, 02:55 AM   #10
Ivan D.
glamoros piece o' lowlife
Ivan D.'s Avatar
Not the case if you have a big battery - the summer of 2006 I lost a cell in the 1000CCA monster in my Lincoln, drove it like that for near half an year, never ever had a problem firing up, even during cold. Ended up replacing it cause I got a good deal on a new Motorcraft battery, also with crazy-high CCAs and also a 4-year warranty. Lincoln has a 302 engine in it, so just as hard to run over as the SBC. Lesson learned - always get the largest fattest most heavy duty battery that can fit in your vehicle
The more I drink, the more I drink, the more I drink...
diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express
Ivan D. is offline   Reply With Quote
Old 12-01-2007, 12:18 AM   #11
Russell
Professional Grade
Russell's Avatar
My GMC used to do that, go wiggle the negative battery terminal and I bet it comes back
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 12-01-2007, 12:45 PM   #12
Zoomad75
K5Camper
Zoomad75's Avatar
I'm betting cable. I had that happen to mine...Then I saw smoke from the cable end. The cheesy bolt on cable end had enough. There was corrosion in the cable and that combined with the cheesy bolt on end provided enough resistance to actually melt the lead on the cable end.
Had to call the wife to run to the parts store and get me a new negative cable.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 12-01-2007, 02:42 PM   #13
knightlife
knightlife's Avatar
well. I fixed it! I swapped a new ignition switch into it, that didnt work, same problem... so I put a new engine to cab grounding strap on, still no go... new negative battery cable and life was back to perfect...
thanx for the hella fast responses all... gave other venues to look at.
this is my chevy family, and I love it!
Old 12-01-2007, 08:27 PM   #14
piecesparts
Parts and more parts
piecesparts's Avatar
In the start position EVERYTHING but the starter and ignition wire to the coil are de-energized. That is a planned thing.... The problem you have, may be in your solenoid or the ignition switch
Old 12-01-2007, 08:33 PM   #15
old Rusty C10
glad ya got it going again and it was a relatively simple fix
Bob
I hate cancer!!
